Question about Regal Lager Phil & Teds Vibe Jogger
The front wheel phil n teds ball bearing broke
SOURCE: Phil and Teds Sport. Front wheel either moves
First of all, I cannot tell you how frustrating the Phil & Teds instruction manual is. Our's had one half inch square pictures that were supposed to be adequate to learn how to use this. As a general suggest there are fantastic videos posted by a third part (not Phil & Teds) that are worth watching.
After several frustrating hours I can tell you exactly how to fix this:
1. Put on the rear brake
2. Sit on the ground in front of the stroller but sit slightly on one side or the other
3. Lift up the stroller so that you can see the pin that you pull to release the front wheel
4. Pull the pin slowly out about a quarter of an inch
5. You should see that there are actually two metal pins (one large, one tiny)
6. Twist the knob you pulled so that the tiny pin does not line up with the tiny circle on the inside of the knob
7. Let go of the knob
If you did this correctly, you should be able to have the front wheel locked in the swivel position even if you tillt the stroller upwards.
I hope this helps. I also hope that at some point Phil & Teds hires someone to help them with their instruction manuals. They have several clever and humorous language in them, but when the document does not serve its actual purpose the humor just becomes frustrating. For the cost of the stroller, the company should be embarrassed that its users are resorting to these online forums to help each other, although I am happy to do it.
Enjoy!
Posted on May 10, 2009
SOURCE: rear wheels on my phil and ted e3 pushchair broken
I'm not sure where u brought your buggy from but try mothercare as they ordered me some new wheels for my silvercross 3D pram.
Good luck. :)
Posted on May 23, 2009
SOURCE: Remove Rear Wheel on Phil and Teds Stroller (Dash)
There is a little push button on the metal bar that runs the length of the stroller.  good luck, my bearings have gone bad on my phil and teds and they told me that I had to replace the entire wheel at 40 dollars a pop.
Posted on May 25, 2009
SOURCE: Phil & Ted's Vibe very stiff front wheel
Hi
I am onto my third Phil and Teds Vibe due to issues with the front wheel. It never ever worked smoothly from the moment it was assembled. The first time the UK distributors Outnabout replaced the pin - no help. The next time they replaced the entire no buggy. The new buggy is exactly the same - stiff front wheel that is back breaking to turn and squeaks loudly. Interestingly, I am waiting for Outnabout to send some lubricant that Phil and Teds have recommended; despite being told by the retailer in no uncertain terms NOT to use lubricant. I plan to return the third and final buggy and ask for a full refund or partial refund and replacement with a Sports buggy model. The wheel mechanism is different on that one. Good luck. As you can see, I am all out of answers.
Posted on Apr 07, 2010
  • 274 Answers
SOURCE: Phil and Teds Sport, front wheel shudder
you can phone Out n About 01234 344230 email: info@outnabout.com they are the importers for phil n ted or try www.buggypitstop.co.uk they service and repair Phil n Ted
Posted on Apr 27, 2010
Phil & teds dash
Hi Paulina
Contact Phil & Teds directly for assistance -
Ask Ted phil teds
Sep 03, 2014 | Mountain Buggy Terrain Pushchair in Flint
Need to replace bush/ bearing front wheel vibe
Hi
We would recommend you make contact with Phil & Teds for assistance
STROLLERS BABY PRODUCTS FOR YOUR PARENTING DAY
Jul 04, 2012 | phil & teds Vibe Stroller
Phil and teds front wheel bearings
Hi
We recommend you contact Phil & Teds for assistance http://philandteds.com/uk/support/repairs-warranty
Apr 27, 2012 | Baby Gear
My Phil & Teds Vibe shakes in the front wheel uncontrollably. Do I need a new front wheel?
Hi!
Assuming your tyres have the correct pressure, uncontrollable shaking in 3-wheeld swiveling strollers is usually caused by bearing slack.
Please check the front wheel bearing. It should allow the wheel to rotate freely but it should not be loose on the axle. (ie. It should not slide sideways on the axle.)
In this case you would need a new front fork/wheel assembly.
Please let a dealer have a look at it. As the Vibe has not been around for very long, you may still have warranty.
I hope this helps.
Erwin de Raad
www.babycare.nl
Oct 13, 2010 | phil & teds Vibe Stroller
Front wheel wobble on phil & ted vibe
ya the is a front bearing that might be out of line contact outnabout they are the importers for phil n ted. Or if you live in London go to www.buggypitstop.co.uk they do repairs on all brands of pushchairs. Thay are very professnial
Nov 22, 2009 | Baby Gear
Phil & Ted Sport V1 wobbles and pulls
It sounds like that the tyre or innertube has perhaps become warped, this can happen when there has been over or under inflation.
I would suggest that you try first with a new innertube (get one from a local bicycle shop with a 'bent valve' as this makes inflation easier). If this doesn't help, then you can then try a new tyre and see if that helps.
I hope this helps.
Oct 01, 2009 | Regal Lager Phil & Teds Vibe Jogger
Removing rear whells from Phil andTeds Classic pram
Press the button and pull the axle out as far as it will go. At the button end is a metal collar - hold this firmly and push the button, without pushing the axle back in. This will loosen the 2 ball bearings at the other end of the axle and you can pull it out. It is a bit fiddly but i just managed it after the same problem.
Sep 05, 2009 | Regal Lager Phil & Teds Vibe Jogger
Wheel bearings on E3 phil and Teds stroller
We had a similar problem. You can get replacement axles from the Phil & Ted website http://store.philandteds.com/parts/index.cat for US$8.99 plus postage and you can get new bearings (FR8-ZZ Flanged Bearings 1/2" x 1 1/8") from www.usabearingsandbelts.com for US$7 per pair including postage. (you'll need a pair for each wheel). If you buy the whole wheel option (US$39)from Phil & Ted it doesn't come with the axle and the axle definitely does not come with bearings. ;( Trust this helps.
Jun 20, 2009 | Phil & Teds E3 Jogger
Mar 01, 2009 | Regal Lager Phil & Teds Sport Buggy Single...
Regal Lager Phil & Teds Vibe Jogger Logo
Top Regal Lager Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Regal Lager Baby Gear Expert? Answer questions, earn points and help others
