Question about Xerox 3001 Copier
User manual how to replaced oil roller
How do you change ink ribbon/cartridge?
It's the ink roller you need to replace - it's on page 3 of the user manual (attached link to it). Canon P23 DHV User Manual Page 3
Jul 12, 2016 | Canon P23-dh V 2 Color Mini-desktop...
How do you change the ink roller in a TI 5005 ii
Replacing the Ink Roller
  1. Press the OFF button.
  2. Remove the printer compartment cover.
  3. Remove the ink roller from the right side of the compartment. Insert your index finger, nail down, under the tab on top of the ink roller. Gently lift the ink roller out of the compartment.
  4. Lower the new ink roller (IR-21) into the compartment and align the hole in the ink roller with the pin in the compartment. Press down until it snaps into place.
  5. Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
The full manual can be found here:
http://www.retrevo.com/support/TI-TI-5006-II-Calculators-manual/id/426ci758/t/2/
Nov 18, 2013 | Texas Instruments Office Equipment &...
I need a sprocket and roller bearings for McCulloch MCP 1510 pole saw
Try Amazon, eBay or you may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Sep 25, 2012 | McCulloch 10" Electric Pole / Chain Saw
Everything works fine, starts fine etc..however after running for just a few minutes it starts making a very load grinding noise and continues until the machine is finished drying...just can't take it...
Hi bpur04...
You have either a bad drum felt seal and or noisy or faulty drum rollers.
You will need to disassemble the drum assembly to replace your felt seal and your drum rollers.
I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
I am also going to include a link for you to download a user manual for FREE.
Please take time to rate me thumbs up
http://www.whirlpoolappliances.ca/assets/svXmW8P-TLAIvzVs3DbbPjHfLrBQ74kI.pdf
Sep 17, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Lost manual on vacum need to replace belt
Remove the bottom cover of the sweeper head, then remove the brush roller along with the belt if still there. Clean the brush end-bearings--the roller ends and the interior of the bushings. Then oil the bearings lightly with 3-1 oil or similar. Place the new belt over the roller and the motor shaft adding any required belt twist (diagram on the casting), then seat the roller and bearings as a unit. Replace the cover and test the roller for running. Hope this helps!
Oct 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Paper feeds crooked, then stops. I can't find the users manual. Do I need to clean the rollers?
you may need to replace the rollers. if its feeding crooked it sounds like one of the rollers isnt grabbing which means its either worn or possibly a tension setting.
May 18, 2009 | Canon PIXMA MX310 All-In-One Printer
Squeaking when i run on nordic track 5100r
My treadmill (American Motion Fitness) squeaks when only when  it warms up. I spray CRC oil onto the front roller bolts which bolt it to the swivel housing and onto the bolts which bolt the swivel housing onto the main frame also onto the rubber bushings which allow the front roller to bounce every time my foot hits the deck. I seem to have to do this 1 per week but it is easy to get at and takes 2 minutes. cheers johnO
Apr 29, 2009 | Nordic Track Nordictrack Apex 4100i...
PSC 1510xi Squeaks badly when copy comes out
Hello Lujacques1,
You can download the user manual for your series printer here. It is free and in pdf format. This should help with your question.
If you do not mind, please rate my help I would greatly appreciate it. Thanks
Aug 23, 2008 | HP PSC 1510 All-In-One InkJet Printer
Replace transfer roller
on google search for Dell 5100cn user manual... you will see a pdf download available. It will give you step by step instructions.
Jul 28, 2008 | Dell 5100cn Laser Printer
Replace oil roller
Reset the machine by turning it off, completely unplugging it, all cables and cords. Leave it awhile (go and have a cuppa) now replug all and switch on.
Aug 31, 2007 | Minolta magicolor 2200 DeskLaser Printer
Xerox 3001 Copier Logo
35 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
