Question about Sunbeam Kitchen Appliances - Others
Sunbeam cg waffle iron bulb
Need a replacement bulb. Missing original
SOURCE: Salton Belgium Waffle Maker
I, too, was searching for that wonderful Belgian Waffle recipe and thought, no problem, I'll just look on-line. I couldn't believe it when Salton didn't have it posted on their site (if they did, I couldn't find it) and was taken to your requests for the recipe. So, I went the whole mile, or should I say traveled over mountains of files, and couldn't believe that my filing system still works after all of these years, the Salton Belgian Waffle Maker & Recipe Guide for Model No. WM-4 was right where it was supposed to be. (And my husband, and prior bosses I should add, have laughed at how I save and file everything. I'm glad I can share this with you all now...
Basic Belgian Waffle Recipe
1 cup all purpose flour
1 tsp. baking powder
1/2 tsp salt
1 tsp sugar
1 cup milk
1 egg, separated
1/2 tbl butter, melted
-Sift dry ingredients together in a bowl
-Add egg yolk and milk to the dry ingredients and beat together thoroughly.
-Beat egg white until stiff, stir 1/4 into batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated waffle mold. The light should be off. When batter is added, the light will go on. When the light goes off again, the waffle is done.
-Makes about 6 waffles.
Chocolate Waffles ("which make great ice cream sandwiches," says the recipe book.)
1 tsp baking powder
1/4 tsp salt
2 tsp sugar
2/3 cup milk
1 egg, separated
2 Tbl melted butter
1 1/2 squares semi-sweet chocolate (1 1/2 ounces)
3/4 tsp vanilla
-Add milk, egg yolk, and vanilla to dry ingredients and beat until well blended.
-Melt butter and chocolate together in microwave or double boiler. Stir chocolate mixture into batter.
-Beat egg white until stiff, stir 1/4 into the batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated heart waffle mold. (Hmm, the WM-4 isn't shaped into a heart??? Oh well, moving onward...)
Serve sprinkled with powdered sugar or cinnamon or topped with vanilla ice cream and chocolate sauce.
Posted on Feb 09, 2008
Jerseybob
  • 11 Answers
SOURCE: Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Posted on Apr 02, 2008
swimfan8
  • 6 Answers
SOURCE: The handle on our 13124 Bella Cucina waffle iron
I had the same problem, so I contacted their customer service at (866) 832-4843.
I was informed they don't replace that part anymore.
Sorry!
Posted on Mar 16, 2009
  • 27 Answers
SOURCE: waffle iron light goes on gut does not heat up...
The most common reason for not heating up is because of a blown thermal fuse. Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on. When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower. (Turned a bit counter-clockwise.) If the waffles are no longer dark enough at the ready beep, you may have to use manual override by watching the steam and smelling the waffle.
Posted on May 25, 2010
SOURCE: No instructions for used Sunbeam#3856 waffle maker
download here:
http://www.retrevo.com/support/Sunbeam-3856-manual/id/952ag122/t/2/
Posted on Jul 28, 2010
How do I replace the coil on my WMB-4 waffle maker?
It's most likely not the coil that's the problem, probably a thermal fuse. Unfortunately, these Made in China waffle makers do not last and are basically disposable after a few short years. Better off replacing it with a good quality, vintage 'Made in USA' Sunbeam waffle iron. You can find good deals online on eBay and Amazon.
Feb 20, 2015 | Cuisinart WMB-4 Belgian Waffle Maker
Manual for sunbeam cg
Here's a link to the manual you're searching for:
Aug 16, 2014 | Sunbeam Kitchen Appliances - Others
Sunbeam CG manual
Here is a link to the actual CG & CG-1 (12 page) owner's manual.
http://www.meba.com/manuals/SunbeamWaffleBaker.pdf
How To clean Vintage Sunbeam CG Waffle Iron Grids?
It will tell you how to clean it properly.
Jul 17, 2014 | Sunbeam Cg-1 Vtg Waffle Maker Iron...
Plug gets hot on my vintage sunbeam CG waffle maker
You can replace the power cord on these models easy enough, as the cord is actually attached to a small black, plastic box that can be opened to replace the cord. You can find cords at home improvement or hardware stores. Before going this route, make sure the wall outlet you are plugging the waffle iron into, is properly grounded. You can check this by using a small outlet testing tool that lights up green or orange if installed properly or improperly. It also checks for reverse polarity, in addition to bad ground.
Jan 13, 2013 | Sunbeam Cg-1 Vtg Waffle Maker Iron...
Looking for used "Sunbeam Waffle Baker & Grill" with Radiant Control w/removable plates. Had one back in 1954. OR...Toastmaster Model #269 "Waffle Baker".
I have a Sunbeam Radiant Control Waffle Baker and Grill with original care and instructional booklet dated 1954,
Jun 08, 2010 | Sunbeam 3852 Waffle Maker
I need parts for this waffle model 3852
I called Sunbeam and found out that they consider it out dated. No parts are available. It still works so I am ok. Now I don't have to keep looking for a part. Thanks
Jan 12, 2010 | Sunbeam 3852 Waffle Maker
I am looking for a replacement rubber foot for our waffle maker. It's the sunbeam 3 in one sandwich grill and waffle maker. It's the little black rubber foot that keeps it from wobbling. Any ideas...
Go to:
http://www.sunbeam.com/ServiceLocator.aspx?section=kitchen
Then select your area from the drop down menu to find out where your nearest service center is.
Best wishes,
Graemevm
Jan 10, 2010 | Sunbeam 3852 Waffle Maker
I have a ventage sunbeam waffle iron model CG and I have to remove the heating elements to repair a broken leg, I have removed all visible nuts and screws but it will not come out, do you have to remove...
Yes, you do have to remove the knob.
you can see a step by step disassembly, with pictures, here:
http://www.lahabraheights.net/SunbeamCG_WaffleMaker/SunbeamCG_Disassemble.html
Dec 30, 2009 | Sunbeam Kitchen Appliances - Others
283 S Waffle Iron.
You can try this site: http://kitchen.manualsonline.com/manuals/mfg/toastmaster/287.html
Its not the exact model but sometimes they are close. Hope this helps.
Aug 13, 2009 | Toastmaster 283S Waffle Maker
Kitchen Appliances - Others Logo
44 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
