Question about Amana Refrigerators
What are the specs of an armana asd2522wrw03?
Asd2522wrw03 specs
Hat is wrong with my armana refrigerator when the top half doesn't get cold
check the fan inside the fridge, if it's OK, you have to refill with gas
Mar 24, 2013 | Refrigerators
I have an amana ASD2522wrw03. The refrigerator portion and the top of the freezer by the frige vent are warm. The rest of the freezer is cold but there is a lot of ice build up. I am assuming that the...
Outside of the unit being very hot then you might have a bad condenser fan motor or dirty coils. If the heavy frost is just on the back wall then you could have a defrost issue, if the frost is all over then the door isn't closing all the way.
Mar 15, 2013 | Amana Refrigerators
Armana lg4319W2
If the dryer does not start and you have power to it, check the door switch for continuity. Here is the part to order in case it is bad.
Nov 05, 2012 | Amana Dryers
Armana APN14K-E portable AC freezes up
Lack of air flow or a lack of refrigerant are the two primary reasons why coils freeze. Clean the filter and the coil, if frost continues it is likely low on refrigerant.
Jun 30, 2017 | Haier Amana Apn14ke-E 14 000 Btu Portable...
Amana ASD2522WRW03 - tHIS UNIT HAS EXCESSIVE NOISE AND IT RUNS CONSTANTLY DAY AND NIGHT -- IS THIS NORMAL? iT IS APPROXIMATELY 1 1/2 YRS OLD.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Amana ACD2232HR Side by Side Refrigerator
We never received a manual and now need to replace the water filter. model no. ASD2522WRW03 - ser. no. S01831393. also how do we order a replacement manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
May 22, 2011 | Amana Refrigerators
My Armana bottom freezer is icing up, and is seems that the suction/seal is not working. How can this be repaired?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 18, 2010 | Amana ARB8057CSL Bottom Freezer...
Used armana bottom freezer fridge, not cooling?
yes leave it on for another 24 hours its probably the settings on the refridgerator
Jul 13, 2010 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
I have a quarter stuck in drain pump on armana front load washer. what do i do?
undo the hoses to the pump two wires and two securing srews remove the pump and try to shake coin out.If this does not work you can strip down the pump to remove it...
Nov 21, 2009 | Dryers
Refrigerators Logo
41 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
