Question about Acer Computers & Internet
Glowing touchpad not working - Acer Computers & Internet
EYO18AA MOUSE DOES NOT WORK.New battery
Check if there is led light glowing if so tap it twice or
Update touchpad drivers
update BIOS
If that does not work its a H/W Issue
Sep 30, 2014 | HP Pavilion Computers & Internet
How to turn the touchpad on and of?
IF IT IS A NEW HP LAPTOP LOOK FOR A BUMP IN THE LEFT SIDE TOP CORNER OF TOUCH PAD ( MOUSE PAD ) DOUBLE TAP ON THAT AREA THEN U WILL NOTICE A LED LIGHT GLOWING NEAR TO THAT...THEN TOUCH PAD IS DISABLED,DOUBLE TAP ON THAT BUMP TO ENABLE TOUCH PAD
Jan 07, 2014 | HP Computers & Internet
Laptop touchpad not working
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 09, 2012 | Toshiba Computers & Internet
I am using HP ELITEBOOK 8460p latop. My touch light glows automaticllay and unable use the touchpad. Please help me
You might have disabled the touchpad accidentally. If the touchpad is disabled it is indicated by a yellow LED on upper left corner of the touchpad and when the TouchPad is active, the light is off.
To turn the TouchPad on, quickly double-tap the TouchPad off indicator (the yellow LED).
Hope it helps!
CreativeTECH
Sep 20, 2011 | HEWLETT-PACKARD EliteBook 8460p Notebook
I don't know what I pressed on and the touchpad was locked !!! How do I unlock it ? I am using ProBook 4421s. ='(
there should be a touchpad tap on the top left of touchpad. press it gentally, touchpad light will glow and it would be enabled ..
May 25, 2011 | Computers & Internet
Samsung omnia i900 touchpad problem
Dear user,
please check if there is any calibration of screen option in your phone settings, if found do as instructed like touching the glowing dots on screen, it may help.
May 04, 2011 | Cell Phones
My keypad does not glow in the dark hard to see keypad
I can't answer this directly, but I will steer you to their Customer Service page:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
There are toll-free numbers listed that you can call.
Feb 24, 2011 | Weiser Lock GED1460X15A Antique Nickel...
The mouse touchpad,stopped working and now the mouse usb,has stopped working.
please chaeck the mouse pad lock mode or any light is glowing on top of the mouse touch pad?
Sep 05, 2010 | Computers & Internet
Hello, I don't know how but the touchpad at the side of my keyboard( To control movies and music) doesn't work anymore =( It's still glowing blue, but my volume doesn't follow the lines, if you know...
try unpluging it and putting it back in - this should update the driver, if not try the device manager and update the driver.
http://www.driverguide.com/ is a good place if the update does not work
Aug 06, 2010 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
