Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 50 inch plasma tv has no red color - Hitachi 50V500 50 in. HD-Ready LCD Television
    Novelist:
  • 167 Answers
I ran into Bee Hive of problems and don't know where to start. I have read problems that are related to the convergence , one definitely a fan motor. A couple sounded like the color IC on the CRT board. Some sound like bad caps in the power section. Some sounded like a picture tube alignment problem. The one that wouldn't turn off sounds like a relay stuck or burned closed. As I read down I noticed some problems that would have to be done in a well equipped shop.. I really don't know where to start. If someone will give me a specific problem I will try to solve it. Reading down I got confused, is this all one TV?
Col. Dana Gillespie
Posted on Apr 15, 2014
SOURCE: my tv is hitachi 55pd plasma
Hitachi did in fact stand behind their product and resolved the problem. My hats off to them! Panel was replaced due to faulty ribbon cable supplying signal from one of the drivers. Unfortunately for my specific issue there wasno other solution as the ribbon cable in sealed inside the glass panel.
Posted on Jan 17, 2008
Drummernick
  • 440 Answers
SOURCE: Hitachi 50" plasma no picture
well they give usaly 1 yr parts labor i would get it in asap to be fixed bad power thx nick
Posted on Feb 07, 2008
eagle338
  • 4889 Answers
SOURCE: p50h401 50 inch hitachi plasma tv
Its difficult to guess what the problem is with the given info. How ever I think its probably the ceramic fuses and burning smell is due to burnt resistors, caps or something else. I would suggest that you get the back panel off take a snapshot(High resolution) of the suspected area of damage so that i can assist you further. By the way you can upload the pic in an imagehosting site like imageshack.us
Posted on Sep 28, 2008
  • 223 Answers
SOURCE: Hitachi 42HDS69 42 in. Plasma with red lines
I think you have dry solder joints on the tv. Either on the chroma board, the vertical scan board, the line output board, or on the focus board. If you are going to do this yourself please take all necessary precautions against electric shock and discharge all capacitors that you can as a stray spark from one can cause damage to your tv and yourself. If you are not able to do this find a competant technician. Good luck.
Posted on Oct 05, 2008
SOURCE: My 50 inch Hitachi plasma 1080 tv has a blinking
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Posted on Feb 08, 2011
Having a problem with plasma tv hitachi
It will depend on the age of the set but the lines are either a bad board or a bad display unit .
Dec 12, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi 50 inch plasma - no sound, no picture, red light on start up in the lamp and temp indicators on the front of the TV.
If it has lamp and temp sensors it is not a Plasma---locate and remove the lamp and look to see if it is shattered inside--owner manual will tell how to remove--its behind a door on right side or rear of set in most cases.
May 23, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Can i connect a regular dvd player to a hitachi flatscreen hdtv?
Yes you can. Simply connect the appropriate color inputs.
If you use red green blue for video, and red white for audio you will get the best picture
If not stick to yellow for video and white red for audio
Just remember color that is on the back of dvd goes to same color on the input for the tv
Mar 21, 2011 | Hitachi P50H401 50 in. Plasma HDTV
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
Mar 27, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi Plasma 50 inch H4011 series just went off and red light blinked 4 times. Won't come back on even after unplugging and waiting 30 seconds and plugging back in per Troubleshooting guide in owner's...
Power supply board is dead.Replaced the power supply board,Ur tv will get the power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Feb 21, 2010 | Hitachi P50H401 50 in. Plasma HDTV
RED COLOR NOT coming on TV, showing green all over place
I also have a samsung 40 inch. Try hitting the menu button on the remote the scrolling over to the right once and scroll down and hit pictures reset to see if that works. If it doesn't check your connections coming from the back of the source and the tv itself.
Sep 03, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 52 projection tv
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
