Question about Dishwashers
Asko dw 1605
No power to the fill solenoid. Is there an interlock to the fill solenoid? Peter
  • Dishwashers Master
  • 3,247 Answers
Yes the interlock would be from the door switch.
Check out item 607 in this assembly schematic.http://spares.bigwarehouse.com.au/images/files/28918_89d4bf910be7ebd72640c42c10f0eec5.png
Posted on Apr 25, 2014
2 Suggested Answers
SOURCE: ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Posted on Jan 04, 2011
ASKO 1605 Dishwasher instruction manual
Hello & Welcome to FixYa
You can download the manual for your Asko unit here. Please get back to me if you have any other questions.
Kevin
May 14, 2011 | Asko Dishwashers
Dishwasher runs even tho the door is open
The door interlock switch is jammed in the closed position.
There is a metal tab on the inside top of the DW frame that engages a lock just behind the handle on the inside of the unit. The lock tells the machine the door is closed and it is OK to run. If that jams the unit thinks the door is closed.
Open the door.
Look for the latch inside the door behind the handle.
Try to release it with a screwdriver.
If you need to you can remove the handle and repair from inside. It is usually a simple jam that requires you to gently pry the latch open.
REMEMBER TO TURN THE POWER OFF FIRST.
Hope this helps. Please rate this if it helps you.
Thanks,
Adrian
May 03, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Our Asko D3250 dishwasher is brand new, and it fills up and drains and fills again and then the water inlet fault flashes. It doesn't go past this point.
this sounds like a improper install ! ck to see if the drain hose outlet is lower than bottm of tank. it should drain to the disposal . and have a drain loop under sink .. the dw prosser is sensing that the drain is longer in time so it flasher inlet fault . . elevate the drain and try again ..if it drains to a lower use a stand pipe or a siphon brake . in the install .. mm
Dec 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
No water running through on start up
it won't fill unless the door is closed & locked.
Check your inlet supply valve (mine is in the basement 10 feet away from the dw)
Jul 23, 2009 | Asko D1716 Built-in Dishwasher
My Asko W6661 washing machine water inlet fault would come on so I check the water inlet line and filter and everything was ok, but the water still would not come into the machine. I than check the...
As the solenoid should should remain power free and closed until the programmer tells the circuit board to switch on the power, it could conceivably be either or both of those things, though I feel the chances are greater the circuit board is at fault.
Apr 05, 2017 | Asko W6661 Front Load Washer
ASKO 1605
Hi Guys
3. Water is hot
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Asko 620 washing machine keeps filling
Sounds like your fill solenoid has stuck in the open position. There are 3 #20 Torx fittings along the back and you can lift off the top panel. The solenoid will be in the back left side.
I would shut off your house water supply to the machine and then do a voltage check to see if the solenoid is remaining energized. Another more simple option is to give the device a few light taps as some debris may have become trapped inside and caused it to become stuck open.
Jul 07, 2008 | Asko W620
DISHWASHER
Make sure you have water coming to the dishwasher. Next check your dishwasher float. Make sure it is not sticking. If not you could have a problem with your fill valve. Check for voltage at the fill valve if you have 120V then you need a valve the solenoid is defective. Replace it.
Dec 24, 2007 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
