Question about Troy-Bilt Super Bronco CRT Garden Tiller
Ground speed is too fast
With rpm up ground speed is too fast
Tickover 1500 rpm when warm
idles too fast.
what engine?
what year?
on a gas engine, the idle speed is 100% controlled by PCM at all times. hot.
so its out of control that means the PCM closes the ISC valve.
and RPM will not drop. (its stuck open) or vacuum air leaks
jeeps use speed density EFI system using the MAP sensor.
this means all air leaks on jeeps , cause wild fast idle speeds.
that is all you need to know , to find problem (find leaks)
clean the ISC yet (idle speed control) valve.?
Mar 28, 2015 | Jeep Grand Cherokee Cars & Trucks
High cruising rpm
no year, no real help.
mike cruises at 90 mpy (Dallas new speed limit 85 on one road)
larry at 75
me 45. so>>>
but doing it backwards works way better
what is speed at 3000 RPM , a common speed.
answer in my 96 goes 59 mph. in 5th gear.
the rpm is a function of what tranny and tire size.
here are all listed
The G16 is no V8 it spins fast and last 300k miles. if serviced.
see this table for 3000 rpm speeds.
there are 5 speeds possible in top gear.
what transmission tell you which it is , there are 3 trans. and 2 engines. each are Unique.
http://www.fixkick.com/part-time-test.html#SPEED
chart one is stock. tires.
chart 2 is big tires.
the equation is there so you can do yours, from any RPM you want.
May 21, 2014 | Geo Tracker Cars & Trucks
Engine stalls, p0720 engine light on. Runs ok than goes sporadic.
There are 2 possibilities here:
1.- There may be a problem with the new speed sensor, the electrical wiring between the speed sensor and the PCM, or an internal PCM problem. To see if VSS signal is present at the PCM a scan tool capable of displaying live data is required.
2.- There is a recall action on this model year for erroneous speed sensor signals; the cure is an updated software calibration. If your truck has not yet had the updated calibration installed, you should call your local Dodge dealership with your VIN number and ask the service department to check to see if there are any open recall actions on your vehicle. If the software calibration has not been updated yet, they will perform this procedure free of charge for you. If you do not have the current software calibration in your PCM to correct the VSS issue, you need to have this done before proceeding any further with attempting to diagnose this problem
This sensor is located at the rear of the transmission.
Symptom: P-0720 LOW OUTPUT SPEED SENSOR RPM, ABOVE 15 MPH
When Monitored and Set Condition: P-0720 LOW OUTPUT SPEED SENSOR RPM, ABOVE 15 MPH
When Monitored: Continuously with the key on, engine running, and gear selector not in park or neutral.
Set Condition: This code is set if the vehicle speed (as determined from the vehicle speed sensor), is above 15 MPH, and the output shaft speed is below 60 RPM for 2.6 seconds.
POSSIBLE CAUSES DTC CODE RETURNS:
OUTPUT SPEED SENSOR DEFECTIVE
PARK/NEUTRAL SWITCH CODE PRESENT
OUTPUT SPEED SENSOR GROUND CIRCUIT OPEN
OUTPUT SPEED SENSOR GROUND CIRCUIT SHORT TO GROUND
OUTPUT SPEED SENSOR SIGNAL CIRCUIT OPEN
OUTPUT SPEED SENSOR SIGNAL CIRCUIT SHORT TO GROUND
PCM DEFECTIVE (DRB SHOWS > 60 RPM)
OUTPUT SPEED SENSOR HARNESS OBSERVABLE DEFECT
OUTPUT SPEED SENSOR WIRING HARNESS INTERMITTENT DEFECTIVE
Hope helps.
Sep 14, 2011 | Dodge Ram 1500 Cars & Trucks
Hi speed of my car 90 the RPM IS 2500 but other
you most likely have an older car or more used car that has more sludge in the engine which makes you need more rpm's to go as fast as a cleaner engine
Aug 11, 2010 | 2001 Hyundai Elantra
What is the speed rate for prossesor fan fpr pentium 4 board
By speed rate, you mean RPM (how fast the fan is spinning)? It should range around 2000 to 3000 RPM
Jun 19, 2009 | Computers & Internet
Fast iddle speed when engine is cold.
This is acting normally then...
I guess it really depends on how cold it gets outside as well as how high the RPM's go...
If your RPM's are above 3500 RPM's then I do suspect something is wrong, and further
info is needed...
Nov 07, 2008 | 1990 Nissan Sentra
Troy-Bilt Super Bronco CRT Garden Tiller Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
