Canon d1320 connect computer
Won't scan error message says connect computer, but my printer is connected via usb
early1234
  • 871 Answers
SOURCE: USB Connection. When connected to computer camera shuts off or displays USB error.
you have a faulty usb cable. try to buy another usb cable which supports usb2.0 for faster data transfer.
Posted on Mar 23, 2008
BinaryCode
  • 54 Answers
SOURCE: SCAN STOPS MIDWAY
10.9.3 or 10.3.9?
Since you are running on a Macintosh environment, lets try to use the generic application by macintosh and it usually is embedded already when you install or get a mac computer.
From you desktop, double click mac hd > go to applications folder then look for Image capture, try to scan from there one by one. This will verify if the connectivity is intermittent or if its a bad cable. If the issue persist when you are scanning from that generic app then you may want to try to use a different cable.
Posted on Jun 12, 2008
SOURCE: I get an error message 2019 and unable to connect to twain device
Make sure that your scanner cable is not tightened too much. I had this challenge and found that by simply loosening the cable connection, this error message dissappeared.
Posted on Aug 21, 2008
SOURCE: Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Posted on Sep 30, 2008
SOURCE: When connected to Airport Express via USB, it will
Airport Express provides only a print server, not a networked usb hub so it can only print. I'm afraid you'll have to go back to wired for scanning.
Posted on Apr 03, 2009
I have an error message on my printer canon mg6460. The message says B200 It is connected wirelessly, no usb
Turn on your wireless option on your printer turn it off and when you turn it on look for the connection via your computer or laptop or tablet.
Dec 27, 2017 | Canon Office Equipment & Supplies
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
Will not scan - says turn off computer and follow manual instructions "error code: 2,255,0
Question: does error show on printer display panel
or on computer?
Can you print?
Connected via USB or Ethernet?
thank you.
Jun 11, 2014 | Canon imageCLASS MF6590 Copier
Cannon d1320 false paper jam
this happens due to overheating of the fuser unit.try resetting it
Jan 25, 2014 | Canon Imageclass D1320, Copy, Print, Scan...
Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Apr 20, 2009 | Canon imageRUNNER 5000 Copier
My 3210 will not scan
I now have 2 of these and both print ok but can not scan with either, never tried to till now.
I have re- downloaded the driver from HP.com via Internet Explorer (usually use Mozilla Firefox) and i get 2 diff. error messages : network busy (impossible since it is connected via USB) and the 1 at my office connects wirelessly but error message is something to do with software.
Thanks!
Nov 02, 2008 | HP Photosmart 3210 Printer
Scanning error - cannot scan error code 2,155,0 ???
Hi
I had the same problem, at first I thought that it was the original drivers (the ones I got with the printer) so I donwloaded the drivers from the canon website, this did not resolve the problem. What I also tried and it worked for me was connecting the printer to the computer with it's original usb cable. I bought a couple of weekes ago a usb extension cable (about 5 m long). With this extension cable I can print but I can't scan any document, it just gives me the same error. Hope this works also for you.
Bye
PS: My printer is a Canon Pixma MP190
Sep 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Printer time out error!!????
is your printer connected with a serial cable, if so, you may have to install the printer and software again, but if you are connected via usb and this is the given error then there is a connection fault as, you may already know that LPT1 is not a usb connection but serial cable.
Apr 29, 2007 | Canon S400 InkJet Printer
77 people viewed this question
k24674
jasbo
jasbo
