Question about Uniden BC60XLT Handheld Scanner
How to program channels into my scanner - Uniden BC60XLT Handheld Scanner
    President:
  • 2,761 Answers
You can download and print the factory manual for the BC60XLT, at no cost, here:
http://www.uniden.com/pdf/BC60XLTom.pdf
Posted on May 28, 2011
Channelslockedout
Hi Barney,
I take it that you have frequencies programmed into the scanner, so this is the solution to your problem.
On the keyboard of your radio scanner you will find a button marked L/O or L/Out, when your scanner is in scanning mode, press the Mon or Hold button, this will stop it from scanning.
Now select the channel of your programmed frequencies, starting with Channel 1. To do this press Hold followed by 1, if this channel shows a L/O icon on the LCD screen, press the L/O button and the L/O icon should go out. continue through each channel, until you undo the L/O from each channel by following the steps I have described above, once you have removed the L/O icon from all the channels that were locked out you can then press the Scan button and you'll be listening to the frequencies that you programmed into your scanner.
Note: If you have not programmed any frequencies into your radio scanner, then you will not be able to hear anything, as nothing programmed to hear and L/O is the default setting on all channels, until each one is programmed with the frequencies of your choice.
How to Program a frequency?
Press Prog button, select channel to store frequency, E.G:Ch:1 168.5000
Remember to always press the (.) decimal button in the correct place, else you will get ERR message on the LCD, now press Enter button, you now have the first frequency stored in you radio scanner on Channel 1, now press the Delay button, so that it doesn't start scanning for 2-3 seconds after a transmission is received.
Continue with the above setup one channel at a time until you have programmed your radio scanner to your liking.
I hope I have helped you in finding the solution to your query.
Regards,
Peter
Feb 22, 2013 | Radio Shack Pro-2096 Base Scanner
How to program a pro - 135200 channel hand held scanner with out charging me .
  1. 1. Press "MAN."
  2. 2. Press "ENT/PGM" to put the scanner in programming mode. You will see PGM appears.
  3. 3. Use the number keys to enter both the channel storage bank and the channel number you want to assign to a frequency.
  4. 4. Press "MAN."
  5. 5. Use the number keys to enter the frequency and don't forget decimal point.
  6. 6. Press "ENT/PGM" to store the frequency into the channel.
  7. 7. you just stored a frequency into a channel. Repeat steps above until you have your scanner programmed how you want.
  • Hope this helps...
Nov 26, 2011 | Radio Communications
How do I delete channels off of my pro-135 handheld scanner?
To RESET the scanner and delete ALL programmed frequencies:
- Power the scanner OFF
- Press and hold the 2, 9, and PSE keys and power the scanner ON.
To delete a single frequency, program 0.0 into the channel - or program a new frequency into the channel (this will automatically override the old frequency).
Bill B.
Listening in since the 60's
Dec 07, 2010 | Radio Shack Pro-95 Handheld Scanner
PROGRAM AFTER ALL LOCKOUT OF ALL CHANNELS ON A BC60XLT-1 SCANNER
With the channel display showing 000.0000 you may be able to program a new frequency into it, and the new program will release the lockout. Have you tried the normal programming for any channels?
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
How do I program my bearcat 144xl scanner?
The BC144XL is one of the few scanners that I haven't been able to locate a manual for, but programming it is fairly straight forward. Here's some guidance from Uniden:
Here are basic instructions for programming nearly all of the older scanners that Uniden produced. When the scanner is turned on press the MANUAL key, then press the channel number that you want to program first, then the MANUAL key again. This will stop the scanner from scanning and hold it on the channel that you want to program.
Then you enter the frequency (be sure to use the decimal point in the right area when entering in the frequency) and then press the E or ENTER button to save the frequency on the channel. You are now finished programming the channel. To advance to the next channel simply press the MANUAL key and enter your next frequency the same way that you entered it on the previous channel (as described at the beginning of this paragraph).
I hope this helps.
Jan 01, 2010 | Uniden BC248CLT Base Scanner
How do i program a uniden bc144xl scanner
I couldn't locate a manual for this one, but here's some programming guidance from Uniden:
I hope this helps.
Oct 15, 2009 | Uniden BC248CLT Base Scanner
Need manual for uniden scanner bc155xl
I couldn't find a manual for this oldie, but here's programming guidance from Uniden:
I hope this helps.
Sep 15, 2009 | Uniden BCD996T Base Scanner
Uniden/bearcat BC-100
If it's indeed a BC-100 and not a BC-100xlt, the 16 channels are easy to program and use.
1. Press MANUAL 3 MANUAL with 3 being the number of the channel you wish to program.
2. Enter the frequency for that channel (e.g., 162.55) followed by ENTER.
3. Follow the same sequence for each channel you wish to program, except that pressing MANUAL after you program a channel will advance the scanner to the next channel.
To scan, simply press the SCAN button after your frequencies are programmed.
Bill B.
San Antonio
Jul 15, 2008 | Uniden BC248CLT Base Scanner
Programming bc147xlt uniden scanner
to program the uniden bc147xlt use the manual button to select channel you want to program. punch in the desired 6 digit frequency then press E, press review to check that frequency was input correctly then use the manual button to go to next channel for programming.MAKE SURE WHEN ENTERING FREQUENCY YOU INPUT THE (.) AFTER THE FIRST 3 DIGITS FOR EXAMPLE GO TO CHANNEL 1 PRESS 149.220 E AND YOU should have no problem programming . hope this is helpful
Dec 11, 2007 | Office Equipment & Supplies
Uniden BC60XLT Handheld Scanner Logo
83 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
