Question about RCA Televison & Video
Will not let me change tint on tv - RCA Televison & Video
Panasonic plasma tv Th50px75u. remote will not change tint or color
The receiver circuitry in the tv for the remote's signals has the problem
Jul 23, 2015 | Panasonic Televison & Video
Why cant i change the tint of my picture? the menue keeps skipping the tint option
If you're watching UK TV broadcasts then we don't have a need for tint. Similarly, with HDMI sources you shouldn't need tint either because the TV's colour decoder isn't active.
Tint is a throw-back to the American analogue TV system called NTSC. Their system doesn't lock the colour phase to the sync signal. So depending how far the TV was from the transmitter the colour would be further and further out of whack. Hence the industry joke that NTSC stood for Never Twice (the) Same Colour ...N - T - S - C. The Tint control was used to re-time the colour signal. The UK didn't have this issue because our TV system (PAL - Phase Alternate Line) includes information to lock the colour signal phase.
Strictly speaking, Tint is only required with NTSC analogue composite signals. This is where the brightness information is mixed with colour on a sub-carrier frequency. So, that would be signals via an aerial lead or from the yellow video connection which is how most of us first see a composite signal. These signals are encoded as NTSC. Any signals where the colour and brightness (luma) information is kept separate shouldn't need Tint. So, S-video, Component and RGB at 60Hz all bypass a TVs NTSC decoder. If the TV is correctly designed then the Tint option should not be available. Some TV manufacturers break the convention though, for the simple reason that many old school US consumers grew up adjusting Tint, so it's too much of a culture shock to take away that feature.
To recap then, if Tint isn't available then it's because the signal doesn't need that adjustment. The colour timing is already bang on accurate.
Sep 16, 2014 | Televison & Video
Entire screen has a pink tint. Can change to blue with settings. Cannot change to natural with tint etc.
Check that all cables are intact and plugged in correctly.
Turn of the TV completely. There might be a manual button on the tv for this. As the last thing, remove the power cord from the power outlet in the wall or where it is placed. Wait 1 min. Then put it back in, swith it on and turn on the TV again.
If this doesn't help and you have tried replacing the cable that you get the picture from (VGA, DVI, Antenna etc.) then it is most likely broken.
Jul 06, 2014 | Sceptre X400BV-FHD 40 in. LCD TV
Picture on tv has red tint will not change with colcr controls
Picture on tv has red tint will not change with color controls. ACL HITACHI 50V500A
Dec 30, 2009 | Sony Televison & Video
JVC 56" Rear Projection - red tint.
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 19, 2009 | Televison & Video
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
Periphery of screen changes tint
hit crt with open palm in distorted area.if changes broken shadow mask no repair except crt replacement. if not could be magnatized. needs degaussing
Dec 07, 2008 | GE 35GT690 35" TV
Pink tint problem with a sharp T.V
Go to TV Menu and check Color System. Change it to NTSC and Tint option will be enabled. Your TV is now working on PAL color system.
Jul 27, 2008 | Sharp Televison & Video
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Televison & Video Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
