Question about Calvin Klein Watches
Zeroing out the larger seconds hand in CK Strive Chronograph - K0K27107
Please explain how to reset and zero out the larger seconds hand in my CK chronograph. I bought this brand new watch yesterday and its larger seconds hand won't adjust at 12 o'clock but stays at 12:01. Your help will be highly appreciated.
ONECCO
  • 3 Answers
SOURCE: Just had battery changed in my Tag chronograph.
I love these watches, don't you?
Posted on Aug 16, 2009
  • 2501 Answers
SOURCE: The chronograph second hand now resets to the 5 O-Clock position?
I have found instructions that tell you how to reset the hands but there are several buttons on your watch and to avoid confusion you really need to see a diagram.
You can do this by going to the Seiko web site (seiko.com), click on "support", then "instruction booklets".
Scroll down the next page and you will see a list of the watches made by Seiko. Select yours and download.
Go to page 16.
Posted on Jan 24, 2010
escapement
  • 2334 Answers
SOURCE: Heuer chronograph second hands will not reset to
Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
Posted on Jan 29, 2010
escapement
  • 2334 Answers
SOURCE: The stop watch is not zeroing
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SEIKO watch manuals.Rate me, please..
Posted on Mar 29, 2010
  • 5 Answers
SOURCE: the second hand on my invicta chronograph watch
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Posted on Sep 29, 2010
The time is accurate, the chronograph second hand works perfectly, stop and reset to zero. The problem that I notice is that the small hands on the left and right do not reset to zero position
This drove me mad when I had a battery changed! In the manual there was a section on zeroing the Chrono hands on my Seiko. Pull the crown to the first (or may and been second) stop and press the button nearest the dial. Each push will move it one second. Stop when you get to 60 and push in the crown.
Oct 09, 2015 | Watches
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
Want to use larger second hand and set other to zero. have small one working now and the larger one would work if i pressed the top button on side of watch now it wont do anything if i press button dont...
This watch is a chronograph. The true second hand is the one you mentioned that is currently running (what is called the subdial hand).
To use the chronograph hand,
1) Press the button at the 2:00 location to start timing.
2) Press the button at the 2:00 location to stop timing.
3) Press the button at the 4:00 position to reset the chronograph hand(s) to zero.
To reset the chronograph hands to zero, set the crown to either click position one (usually date setting) or two (usually time setting), and use each button to test which subdial hand it will zero out.
Usually it is the first crown click position, and pressing the 2:00 or 4:00 button to zero out.
Warning: Leaving the chronograph function running will drain your watch battery much faster than using the standard second hand, as it is a complication meant for the purpose of timing an activity or other event.
If this does not zero your watch, you must either send it back to Michele, or visit your nearest Certified Master Horologist to assess the issue, as the movement may have a defect.
Feb 25, 2011 | Michele Coquette 71-800-CL-301-72 Wrist...
Stop watch not zeroing
Pull out winder 1 step and us the push buttons to adjust hands to 12 o.clock . when you have done this pull winder right out and use push buttons to set other hands then push winder back in.
Jul 06, 2010 | Tag Heuer Aquaracer Quartz Chronograph...
The minute counter on my chrono won't reset to zero.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Jul 30, 2009 | Pulsar 100 Meter Alarm Chronograph PF3277
Need to know how to operate Cartier Tank Francaise Chronography W
The top button is for chronograph function and puts the chronograph seconds hand in motion. The bottom button is for resetting chronograph seconds hand to zero.
Do as follows:
1) push the top button once- seconds hand starts moving,
2) push the top button once more- seconds hand stops,
3) push the bottom button once- seconds hand returns to zero.
You can repeat as many times as you like- seconds hand will allways start the countdown from zero.
Depending on what movement your watch has(mechanical or quartz), there can be more variations, but the basics are as described.
If you need more info, supply full info of your watch(make, model, numbers, etc.), please.
Do not forget to rate, please.
Jan 10, 2009 | Cartier Tank Americaine W2601156 Wrist...
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
23 people viewed this question
Top Calvin Klein Watches Experts
Joseph Hoffmann
aravind shet
aravind shet
Are you a Calvin Klein Watch Expert? Answer questions, earn points and help others
