Question about Orion PM4202 Television
No picture on lcd tv orion model tv37rn10da
When power switch is pressed picture +soundwill work ok but after approx 10 secs the picture goes off but the sound stays on.The tv is a ORION tv37rn10da.
4 Suggested Answers
SOURCE: lcd tv no picture
hdfghdfhdfnd
Posted on Jan 07, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: picture goes black but sound
The inverter circuit that provides power for the set's backlight is not working properly. The LCD panel itself still works, but without the backlight you can't see the display. A replacement may be available for your set. Try a Google search for "replacement inverter" for your particular model. A good source for parts is www.shopjimmy.com.
Posted on Apr 22, 2009
SOURCE: Orion TV-32082, no picture
try fuse f404 on power board, feeds av and other screen circuits but not sound and tuner
Posted on Mar 13, 2011
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Volume goes up, picture freezes, tv reboots
Sounds like a surge to me. Why not give Vizo call to see if anyone else is reporting the same problems. It's a fantastic tv.
Apr 22, 2014 | Vizio E421VA 42 in. LCD TV
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
No picture or sound
Hello Sirs, you need to publish the TV brand name & the model number.
Jan 13, 2018 | Toshiba 32BV700B 32 in. LCD HDTV
The tv doesn't power on, it trys to power up, but then goes off, the blue power on button to the left is blinking. Please help, thank you
If you go jvc .com enter your model # ,there is an article on how to reset the tv. First you have to unplug your tv for 10 secs., plug it back in and press and hold the menu and vol- buttons while holding these buttons in press the power button once, count to 3 and release the menu and vol- button. The lillte blue light should be on. wait for 40 secs. the picture should now come back on. This worked for me, I had the same trouble.
mike
Jan 12, 2010 | JVC LT42P789 42 in. LCD TV
Will not switch on
There's a problem with the video card of the lcd TV  needs replacement .
some chip are damaged .or gets over heated eg processor .
Good luck
Oct 03, 2009 | LG 42LC2D 42 in. LCD HDTV
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
TV SWITCHES OFF
Very likely a power supply problem.
Most modern sets monitor power supply performance continuously and if a higher drain circuit is drawing excessive juice, they are designed to shut down to avoid burning down your house.
After all, no house, no new TV needed -
I would be sniffing around the top vents on the set to detect possible 'hot' odors coming from it.
Jun 11, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Orion tv32RN10D Digital problems
factory reset hold volume button on tv down all the way while holding it down hold number 1 on your remote goes to stanby turn back on..
Jan 08, 2008 | Orion HDLCDVD225 22 in. LCD TV
Orion PM4202 Television Logo
85 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
