Question about HP Compaq nw8440 Notebook
What is my Laptop's Bluetooth Pairing "Passcode?"
I am attempting to pair my Nokia 6085 Phone with my Compaq nw8440 laptop. However, the Nokia keeps asking for the laptop's "passcode," which I don't have, and can't determine how to change/set it.
  • aunjanwysan Jun 18, 2009
    No, *not* the Cell Phone's PIN. I have that. It's *after* I enter that, that the Nokia asks for a "passcode." And, there is no way to move forward unless some data is entered.
    NO, please READ what I'm typing. That is NOT what is happening. I do what you say, and then the phone asks for a "Passcode." I must then enter *something* to proceed. And, no matter what I type in, I get a "Pairing Failed" response.
U dont need to look for a pass code anywhere.
when ur laptop finds a new device and when u click on pair it. just put ant thing as code like 1234. then in ur nokia mobile when it ask fort code write over there 1234. and u r done :-)
Posted on Jun 18, 2009
How to reset the 360 Bluetooth passcode
Just delete the existing pairing from your phone and repair it (the default pairing code is always 0000).
Apr 11, 2012 | Plantronics Explorer 360 Bluetooth Headset...
I cannot pair the SPH-M300 phone with my laptop using the PIN code 0000, how do I establish the PIN code of the handset?
When you turn the bluetooth on and try to pair the laptop and the phone, the phone should automatically ask you for a passcode. You could try pairing the other way around, instead.
Jul 06, 2011 | Samsung SPH-M300 Cellular Phone
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    Pairing with a motorola bluetooth device
    Hello, Barb.
    Here are some instructions from the manual:
    To set up a Bluetooth connection, do the following:
    1. Select Menu > Settings >
    Connectivity > Bluetooth.
    2. To activate or deactivate the Bluetooth function, select
    Bluetooth > On or Off.
    Indicates an active Bluetooth connection.
    3. To search for compatible Bluetooth audio devices, select
    Search for audio enhancements and the device that you want to connect to the phone.
    To search for any Bluetooth device in range, select Paired
    devices. Select New to list any Bluetooth device in range.
    Scroll to a device, and select Pair.
    4. Enter the Bluetooth passcode of the device to associate (pair)
    the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
    Hope this helps.
    Apr 19, 2010 | Nokia 6085 Cellular Phone
    Pairing Nokia N78 with Motorola S805
    pair using the wired headset first and that will sort
    Jan 09, 2009 | Motorola Mobility S805 Wireless Headset
    Bluetooth pairing Nokia N95 with Toshba Satellite
    btooth has several stages
    search
    authentication
    pairing
    coneect etc..........
    passcode is required in authentication
    it is very simply
    the passcode can any natural number
    the same that u use in the first device should be use in the second devise when asked.
    if you type 1 on first device .
    the same 1 should typed on the second device
    this is for your security. that u r connecting with the required device
    Dec 14, 2008 | Nokia N95 Cellular Phone
    Security code for nokia 6126 pairing with a jabra 250 bluetooth
    hey! if you want to pair the bluetooth if 00000 mean same code want to give the pairing device then only you can pair the device! other wise use single digit 0 or 1.
    all the best!
    Sep 21, 2008 | Nokia 6126 Cellular Phone
    Pairing Nokia 9300i with Visor Lite027 passcode needed
    The default code for bluetooth pairing is "0000". :)
    Feb 12, 2008 | Nokia 9300 Smartphone
    Nokia 6102i will not detect my BH-600
    Hey I found the solution :
    1. When the headset is off, press and hold the multifunction key until the indicator light is continuously displayed.
    2. Switch on your compatible phone.
    3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
    4. Select the headset from the list of
    found devices.
    5. Enter the passcode 0000 to pair and connect the headset to your phone.
    In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
    If the pairing is successful, the indicator light starts to flash slowly, and the headset appears in the phone menu where you can view the currently paired Bluetooth devices.
    The headset is now ready for use.
    Enjoy..
    Pavan
    Jan 27, 2008 | Nokia BH-600 Wireless Headset
    HP Compaq nw8440 Notebook Logo
    660 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
