Question about Refrigerators
The refrigerator is 8 years old. the refrigerator
The refrigerator is 8 years old. the refrigerator side is not keeping food cold although on coldest setting.
the freezer section appears to be ok?
any suggestions?
what is normal life for this model?
should I repair this one or get a new one? if so, suggestions.
Thanks
Jenn Air JSD2789GES
  • 286 Answers
Any refrigerator should last around 14 yrs. The freezer must be frosted up. I would try to defrost it and then start it back up. If you have a defrost problem you will see this again inside of a week. Also make sure the evaporator fan is operating.
Posted on Jun 19, 2009
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
My fisher and paykel refrigerator keeps freezing my food, then its ok, then it freezes up my food again, I have adjusted it, but still no good.its 8 years old
you will need to check your damper door between the freezer and refrigerator compartments and watch to see if its opening and closing when you adjust your refrigerators cold control,then if it doesn't move after adjustment the control will need to be replaced
Jan 08, 2010 | KitchenAid KSCS25FKSS Side by Side...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Whirlpool intgrated fridge/freezer is not keeping
7 is coldest. but how cold is the freezer? all cold is made in freezer. ma be developing a frose problem
Jul 06, 2009 | Whirlpool ED2GHEXN Side by Side...
Freezer is coldbut the fresh food side is warm
there is probably something wrong with the defrost if you dont take the bak off and defrost all of the ice off they will freeze back up in no time
Apr 24, 2009 | Frigidaire 22.6 cu. ft. Side-By-Side...
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Nov 24, 2008 | Jenn-Air JCD2389G Side by Side...
GE side by side Refrigerator approx. 8 years old. Fridge side barely cold.
With your fridge, does the light go out when you shut the refrigerator door?
That could be your issue, that light running inside will create Alot of heat.
Also check to see if there is air circulating from the freezer to the fridge side through the damper. The damper is on the Fridge side left wall up towards the top. That is where the cold air gets to the fridge side. If that damper doesn't open that will also cause your problem, Let me know how you make out.
Bill
May 14, 2008 | Refrigerators
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
