Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
Does the spacemaker laundry have a washer belt?
3 Suggested Answers
  • 574 Answers
SOURCE: Ge Spacemaker Laundry the washer knob popped out
take knob off again and look at the stem where the knob goes does it have a round side and a flat side? if so the knob will have the same profile thats the way it goes on
Posted on Sep 09, 2009
rickyrt441
  • 4399 Answers
SOURCE: WASHER WILL NOT AGITATE, MOTOR
Thanks for choosing FIxYa and welcome to the site. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter.
Posted on May 07, 2011
Model wwp1180g
Look at it carefully to see whats in the way of the belt removal. If its still on the unit best to take some pics of it so you have a reference to make sure everything goes back where it should.
Aug 20, 2014 | GE Spacemaker Washer and Dryer Electric...
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
Wsm2700dawww dryer will spin laundry still wet
Possible that the speed is of the spin is not enough, check the belt , check for friction to the shaft in the washer.
finally check the drain valve /pump as if there is water logged on without flushing then the valve is clogged or dirty.
Aug 23, 2012 | GE WSM2480DWW Unitized Spacemaker Washer...
My washer will not drain. I heard that this could be caused by a loose belt on one of the pumps. What is the best way to access this?
Sorry to read about your problem, I hope this helps you out.
Their is no belt for the water pump..you may have a defective or clogged pump
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
323m3m
Dec 21, 2010 | GE Spacemaker Washer and Dryer Electric...
Sep 09, 2009 | GE Spacemaker Washer and Dryer Electric...
GE WSM2480TBAW Spacemaker Laundry, Won't Drain or Spin
you need to remove the slanted panel between the washer and the dryer. There will be 2 screws holding the top of the washer to the cabinet. Locate the screws on the back edge of the washer top along with the 2 brackets that hold the top.
Once the brackets have been removed, the washer top panel will pull toward you and lift off of the cabinet. You will be able to see the lid switch and test it. If you are testing the lid switch for continuity, remamber to activate the switch while testing. If the switch shows an open circuit, replace the switch.
Please let me know if this hhelps you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | GE Spacemaker Washer and Dryer Electric...
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
10 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
