Question about GE WSKS2060WWH Top Load Washer
Getting to the motor on a spacemaker washer and dryer
Hoe to you take off the panel and get to the belt?
3 Suggested Answers
SOURCE:
catriver
  • 878 Answers
SOURCE: Washer/Dryer
lincoln, there should be two clips on each side just below the top. Take a puddy knife and push in on the clips. The front panel should release and pull foward. Catriver..post back.
Posted on Mar 15, 2007
Krazytech
  • 725 Answers
SOURCE: ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Posted on Dec 25, 2008
I have a GE stackable unit and I recently broke the belt on the washer- I think. Can I fix it? How do I get the unit open? Thank you for any assistance you can give.
Two screws on the very bottom, remove them and take something flat and insert it in the crack where the washer top is and the front panel. The front panel will slide down and out towards you...if no water is in the unit then push the tub back towards the rear and the motor will lift enough to work on it, replace the belt around the main pulley and then push the spring loaded pulley towds the left towards the main pulley and slide the belt onto the motor pulley...
Apr 10, 2011 | GE Spacemaker Washer and Dryer Electric...
The belt in my dryer is squeeking. What type of
It's probably the front tub guides that are worn out causing the squeak. It's a felt lined circular shaped guide that holds the front of the tub. The rear of the tub is held by a ball and socket bearing. Access to the guides is behind the front panel of the dryer. Remove the screws across the top
May 10, 2010 | GE Spacemaker Washer and Dryer Electric...
My Dryer portion of my GE stacked washer/Dryer will turn on and I can hear the motor running but the drum will not turn. I pretty sure is the belt. I haven't been able to locate a schematic anywhere of the...
Not that easy but go to this web site www.applinace pros.com and look at it's diagram and you can see if you want to tackle this issue, if you do and rn into problems you can get help from us here if you need it.
Nov 13, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Need to inspect tumbler, belt etc. Hoe do I get
Unplug the dryer.
Open the door.
Remove the 4 visible screws.
Raise the hinge side of the door and remove the door,
The front panel will pull out.
Remove 2 screws on the top right and left of the cabinet just under the top panel.
Raise the top.
You will also have to remove the front drum support. 2 screws right and 2 screws left.
Mar 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Smells like belts are burning during rinse cycle while washing
TAKE OFF THE FRONT PANEL BY TAKING OUT THE TWO SCREWS AT THE BOTTOM. SLIDE THE PANEL DOWN ABOUT HALF AN INCH AND THEN PULL OUT. YOU CAN NOW SEE THE INNER WORKINGS. AS FOR PARTS, TRY WWW.MARCONE.COM
Jan 07, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
GE Spacemaker stackable washer/dryer
The front cover come off by removing two philips screws on the bottom of the panel. That will expose all the operating parts of the washer.
Sep 17, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Ge spacemaker washer and dry stackable.
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
You should go in through the front. Use a flashlight and look between the front panel and the top panel. You should see some clips there. Stick a flathead screwdriver into the clips to pop the top up and then remove the front. The front may be held in by screws, but since I don't know which model you have, look inside once you pop the top and see if there are screws. Then you should be able to remove the front panel and see the belt.
Mar 26, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer/Dryer
Mar 15, 2007 | GE WSM2480DWW Unitized Spacemaker Washer...
GE WSKS2060WWH Top Load Washer Logo
23 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
