Question about GE GBS22HCR Bottom Freezer Refrigerator
Only the bottom section of the freezer is cold
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
MNTECH
  • 1543 Answers
SOURCE: Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Posted on Oct 20, 2009
  • 152 Answers
SOURCE: The frig is not cold, the bottom portion of the
You have a defrost problem either defrost heater or a bad thermister
Posted on Feb 17, 2010
  • 3 Answers
SOURCE: fridge working not cold no freezer section
first you should check the termostate how much temp you keep.then if your compressor is working properly so check the refrigerant in system.it may be more chances lake of the refrigerant.oil increase in L.P side.you also should check the thermostate is proper working or not.chaces of low pumping in the comp.either door gasket likage or freezer door ofently open.
Posted on Feb 25, 2010
  • 6 Answers
SOURCE: The freezer section is cold
something in auto defrost circuit has failed heater, timer,defrost thermostat,wiring call for repair
Posted on Mar 25, 2010
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Zanussi integrated fridge freezer, top half fridge not working
It appears you need to get the cold distributed from the freezer section to the frig section. This can only be accomplished by a fan that forces the cold air throught openings between both sections. Since the freezer in at the bottom, cold air cannot go upward, thereforethe fan. Chech that the interior fan (in the freezer section) is running. Check that the air openings between the sections are not blocked. Finally, if all looks good, then maybe the compressor system is slowly failing and only making enough cold for the freezer, but not enough to be circulated. Goodluck, Macgivor
Jan 02, 2010 | Refrigerators
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Fridge not cold enough, Freezer ok
The refrigerator gets its cold air from the freezer section through ducts and damper control. Check for blockage.
Apr 27, 2009 | Candy CPCA240FFK Bottom Freezer...
My refrigerator is too cold
sounds like you have a defective temparture sensor
Apr 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
Side-by-side fridge is freezing food on bottom shelf
Look to the freezer section for a possible frosting on the back wall. If you have a defrost problem in the freezer and air circulation stops cold air from the freezer may settle through the return area of the duct between the refrigerator and freezer section because cold air is heavier the warm air. Normal circulation follows a clockwise pattern.
Also your setting of the refrigerator temperature may be set to cold. Once again cold air settles to the bottom.
Jun 02, 2008 | Whirlpool Refrigerators
Freezer work and no cold on the top section
The defrost controller was changed and it resolved the problem. after a day power off to permit the ice to melt.
May 28, 2008 | Maytag MBB1954G Bottom Freezer...
GE GBS22HCR Bottom Freezer Refrigerator Logo
16 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
