Question about Dyna-Glo D-E37 Wall Mounted Panel Heater
Have gas coming out but takes for ever to light
2001 ford windstar brake lights, signals, reverse lights wont work. Gas gage wont work
Take it to your local FORD dealership,their probabbly the only ones who can fix that.
Nov 06, 2013 | Ford Windstar Cars & Trucks
1993 Topaz- Engine light coming on and smell gas
Take it to autozone and have them tell you what the check engine light code is (it's free!).
Jan 14, 2013 | 1993 Mercury Topaz
CHECK GAS CAP MESSAGE COMES ON
when the light comes back on again take it to your neighbor hood auto zone auto parts they can do a diagnoses for free and tell what the problem is.
Sep 17, 2012 | 2008 Buick Lacrosse
Canister and switching valve sticking toyota camry 2003
Then the gas cap was not the problem. Who told you top replace the gas cap? Will they take it back?
Jun 12, 2012 | Cars & Trucks
Engine check light is on what i can i do
Most of the time Check engine light will come due to Gas and gas cap issues. If you ran out of gas and gas lost pressure it will bring the light on. Make sure to fill take with premium (91 octane) gas and make sure gas cap is closed completely. loose gas cap will cause the engine light to come on. If after doing this you still get the engine light warning, take to authorized mercedez deal for code check.
Feb 17, 2010 | 2007 Mercedes-Benz C230 Sedan
Ka gas range the glow bar comes on but it takes sometimes 15 to 20 min before gas is supplied to burner in oven and finaly ignites
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 22, 2010 | KitchenAid KGST307 Gas Kitchen Range
I accidently pulled my rear view mirror off . how do i put it back on ? i have a 1998 acura 3.2tl . Also,my gas light does not come on ? do any 98 tl"s have gas lights when the gas is low ?
Take it to a auto glass repair place, they'll charge $10 if anything (it take them under 5 minutes to stick it back on for good).
I don't know about the gas light, but you do have a gauge, when the little needle hits the "E" it means your outta gas. :)
Dec 06, 2009 | 1998 Acura TL
Average fuel milage with fuel light on
The light is an indicator of being on "reserve". Some bikes this is anywhere from a quart to a gallon left in the tank. I have two different Harleys and both of them the indicator light comes on at different fuel levels!
To keep from running out of gas I know I get about 190 miles on a tank on the highway (2003 Road King, 103", S&S570G cams, Ported HTCC heads, 10.5 CR) and about 170 miles on combination riding. When you see the light come on look for a gas station! As sson as the light comes on fill up the bike note how much gas it takes, subtract that fron you tank capacity and you will know how much fuel you have left when the light comes on. Take that "fuel left" amount multiply it by you MPG numbers and you will have a guess as to how far you can go on the remianing fuel.
Nov 09, 2009 | 2005 Harley Davidson FLHT - FLHTI Electra...
Gas light in 2001 stratus
Take a gallon or two gas can with you. When your light comes on, mark the miles, then drive till it dies. This is how many miles you can go.
Aug 12, 2009 | 2001 Dodge Stratus
Dyna-Glo D-E37 Wall Mounted Panel Heater Logo
Top Dyna-Glo Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
