Question about Home
Which make & model of toilet is best?
1). Priority is a 17" wide tank. (No wall mounted units - too invasive for our older home). 2). 16" - 16.25" tall bowl height. 3). GPF of 1.6 (gallon per flush) 4). Gravity (no assist). Installed on 2nd flr. 5). 3"-4" flush valve 6). Large diameter + smooth coated trapway/colon. My husband installed a new 1.6 gpf. However with a "Chair Height" 17" tall bowl, it's way too tall for either one of us to be seated comfortably. Don't want to make the same mistake twice. Which make/model will fit our criteria without breaking the bank? *Note: our 1st flr 1/2 bath has a Kohler Cimarron that we just love, (the 4" valve is awesome) but the tank is too wide for our 2nd floor application! (Do overs are never fun). Anyone reading this... please! do yourselves a HUGE FAVOR... find a showroom and actually SIT on various height models to find the height that is most comfortable for you. Afterall, you wouldn't buy a mattress without testing it 1st. Same holds true for one of the most used fixtures in your home, you'll be enjoying it for years, it's worth your time, you'll be very glad you did!
  • 63 Answers
SOURCE: Master bath toilet replaced with a Cimmeron class
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Posted on Mar 16, 2009
  • 659 Answers
SOURCE: What toilet is best.
American Standard Cadet
Posted on Apr 10, 2009
  • 659 Answers
SOURCE: Great unit!
Thanks
Posted on Apr 11, 2009
manhandy
  • 146 Answers
SOURCE: Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
Posted on Jun 24, 2009
  • 65 Answers
SOURCE: I have bought only TOTO
Gerber avalance is a great toilet if you can find, is ada 18'' with seat
Posted on Jan 26, 2011
Which toilet is best?
I replaced the 2nd floor toilet in my house several years ago. It has all the features you require, except the 17" tank width. If you can fit a 20" tank ( actually 19 3/4") then the brand to buy is Toto. The quality is unsurpassed.
The (included) *seat* height is 16 1/8". GPF is 1.6, but the flush is amazingly powerful. I opted for the special self cleaning coating they call "Sana Gloss". Nothing sticks to it, it doesn't stain, and I've never had to use a toilet brush nor bowl cleaner on it the whole time I've owned it.
I bought mine from an online distributor. Just Google "Toto". I haven't checked recently, but they may have a narrow tank model. Mine has the extended bowl.
Apr 15, 2014 | Home
Which is the best toilet?
American standard cadet III is a nice flushing toilet that is reasonably priced. The tank is smaller than the cimarron. Toto also makes good flushing toilets that would fit your needs, but you will pay more for it too.
Apr 15, 2014 | Home
How can I remove the Flushmate 503 to access the mounting screws at the bottom of the tank?
You will need to remove the china holding tank from the toilet bowl by removing the nuts on the underside of the china tank.
After you have the tank off the bowl, remove the two plastic lock-nuts used to mount the Flushmate into the china tank and slide the Flushmate out of the china tank.
After you install the new tank-to-bowl bolts & washers, reverse the process to reinstall the Flushmate unit and remount the china tank.
Mar 01, 2013 | Home
My geberit in-wall toilet won't stop running, and there is no way to access any type of plumbing fixtures to fix. Please help me!
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
Nov 29, 2010 | Duravit 111335001 Geberit In Wall Carrier...
I have 11.5 inches from center flange to wall. This toilet requires 12 inches. Is there any give?
Hello. If you already have this toilet set it tight against a wall and measure to the bolt holes. I personally think the toilet will mount @ 11 1/2" but will leave less space than ideal between the wall and tank.
builderdale
Jan 24, 2010 | Villeroy & Boch 9M08 S1 Twist Toilet Seat...
Toilet - 14 inch rough in
Hrm, I see what you mean and this may be a bit late.
The 14" rough in is not standard (as in 12") and the depth (from the back of the tank to the front edge of the bowl is your concern here?).
Kohler also has a Sterling brand with the Windham model. This will sit on the 14" rough and measure less than 30" from the back wall.
You could also go with a Toto ($$$ concerns) as they have a unifit system that allows for adjustment from your roughed in closet/toilet flange. It basically mounts to your flange and then sets back 2" or 4" depending on which model Toto toiler you are installing. The Soiree-?sp may be your best bet for depth concerns, but not so good for your wallet.
Chris
Jun 13, 2009 | Crane Plumbing Toilet To Go Tall...
Home Logo
1,170 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
