Question about Frigidaire Affinity ATF8000FS
Affinity ATF8000FS won't drain - Frigidaire Affinity ATF8000FS
  • Frigidaire Master
  • 5,323 Answers
PLUGGED PUMP OR HOSE LINES?
Posted on Mar 31, 2015
My washer wont drain
check the filter then the pump
Dec 13, 2015 | Frigidaire Affinity ATF8000FS
How do I remove detergent tray?
Good Afternoon friend, thank you for your post!
From the information you have provided you need assistance removing the detergent tray from your Frigidaire washer, ATF8000FS. In order to remove the tray you should be able to push down on the push arrow and pull the out on the drawer. It should slide right out. If you have any troubles please feel free to reconnect. -Matt
Mar 13, 2015 | Frigidaire Affinity ATF8000FS
What is e70
Good Morning Ronald, thank you for allowing me to assist you!
Typically error code E70 indicates that the hoses on your washer may possibly be reversed. This causes your washer to think the water temperatures are incorrect. I recommend checking the hoses and make sure they are located on the correct valve and faucet. Also confirm that there aren't any restrictions or kinks in the drain hose.
I ask that you please follow up with a comment, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully.
Best of luck!
Jan 26, 2014 | Frigidaire Affinity ATF8000FS
After the wash is finished in my frigidaire affinity ATF8000FS, I noticed that the fabric softener remained in the dispenser. ????
You will need to open the dispenser and clear the internal channels out.
There is a service manual available that shows you how the internal dispenser works if you should need it.
Feb 18, 2013 | Frigidaire Affinity ATF8000FS
It washes but won't spin the water out, very frustrated considering its a brand new machine.
brand new machine, you have warranty, contact the manufacturer or place of purchase and request service
Aug 31, 2011 | Frigidaire Affinity ATF8000FS
I have an affinity washer, stackable, model atf8000fs1, it runs for 15 minutes and quits, help
sounds like it has a bad timing cycle when it reaches that point the catch for the next cycle don't engage if this is the case the timer will need replacing i suggest contacting a service dept hope this helps
Aug 30, 2010 | Frigidaire Affinity ATF8000FS
Frigidaire Affinity ATF8000FS gives me an error code of E48. Stops a few mins after cycle begins
I have the same code and problem...E48:Board thinks the PTC circuit is closed. Any help?
Jul 24, 2010 | Frigidaire Affinity ATF8000FS
Will not spin
not advancing to spin cycle. usually mis communication between the user interface and central control unit. need a tech.
Jun 24, 2009 | Frigidaire Affinity ATF8000FS
Shaking and Spinning Unevenly
Beneath the front panel you may find screws. To have access to your filter. Check the drain to make sure it isn't clogged, also the drain hose.
Re the shaking, etc you have to check for any dampers (shocks) that have come off or broken, also springs.
Mar 19, 2009 | Frigidaire Affinity ATF8000FS
Frigidaire Affinity ATF8000FS Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
