HP DeskJet 2512 Inkjet Multifunction Printer Copier Scanner Logo
A
Anonymous Posted on Apr 15, 2014
HP 60 INK
CAN I USE HP 60 INK IN DESKJET 2512 PRINTER
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jul 10, 2008
SOURCE: printer deskjet 3650
saks
Anonymous
  • 84 Answers
  • Posted on Oct 18, 2008
SOURCE: hp deskjet 6122
GO TO MAINTENCE IN THE PROGRAM AND CLEAN HEADS AND ANSWER THE QESTIONS
Anonymous
  • 52 Answers
  • Posted on Mar 06, 2009
SOURCE: HP DeskJet 930c is leaking black ink
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
ginko
Ginko
  • 19396 Answers
  • Posted on Mar 07, 2009
SOURCE: is the hp deskjet D2560 #60 ink, refillable?
You find the refill instructions in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: HP Deskjet D2560 inkjet refill products.
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
  • Posted on May 31, 2009
SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
How do I get the ink cartridge out?
Pull the front panel forward towards you from the top. It will drop down on a hinge. The printer will return the cartridges to the removal position. Next lift up the retaining lever at the top of the cartridges. They should now simply tip back and lift up & out.
Printer won't print after re-installing cartridge
Do you get an error message? Some of the newer HP printers are designed to damage the ink cart when it's empty, so you can't refill it. Perhaps?
You may want to try cleaning the contacts on the cart and if that doesn't work, try a new/fresh cart.
2answers
I removed cartridge to check for ink smears, then replaced it. Now it won't print.
never take a cartridge out,now it doesnt recognize it,get a new cartridge,or call hp
How do I Print in black and white only?
Color options, which also mean no color options are set in the program you are using to print. The printer just does what the program, like word, adobe photoshop, paint etc. tell it to do.
How to make text larger in HP Deskjet 2512
you adjust the font size in the document IN the computer software
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: [email protected]
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
2answers
k24674
Grand Canyon Tech
Grand Canyon Tech
