After about a few minutes of playing a record the the player slows down. Some times it will speed back up, and play correctly. Other times it will play slow until I try to adjust it. Can you suggest a fix?
SOURCE: My turntable is playing a tad slow...it makes every record sound warped!
Hi CGS8021
Sounds like the belt is failing. You can get one from here
Where in the world are you? I will link you to the closest source.:)
regards
Robotek
SOURCE: Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
SOURCE: how can i fix my jta-460 from playing records slow
Check the RPM switch on the turntable is on the correct speed for the record you want to play. Otherwise it could be a belt problem internally.
