Question about Jensen Vm9414 Car Video Player
Sd card is stuck - Jensen Vm9414 Car Video Player
My memory card won't lock in place therefore I get a "no memory" card message.
Unfortunately it sounds like the locking clip inside the SD card slot is broken or some how stuck? If you can try to look inside the SD card slot in the camera with a flash light, there should be a small clip like plastic to the left sticking out. That is what locks the SD card in place. See if anything is stuck in between like debris, you might gently poke that clip and see if it is stuck? That is what locks the SD card in place, if it is broken or missing, that will require some work to replace the plastic lock.
May 25, 2014 | Canon PowerShot SX10 IS Digital Camera
Tried formatting sd card on jazz dv140 but its stuck on waiting, why?
Mine did the same thing. Come to find out I had the wrong SD card. What walmart sold me was an SD Adapter card. So make sure you have the right type of SD card.
Aug 25, 2013 | Video Cameras
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Sd card stuck in acer a 510
Its your fault dude because you entered SD card from its back it will come back with the help of pin
Nov 11, 2012 | Acer Iconia Tab A510 Tablet
My SD card is stuck in my SD slot. im guessing the SD was too small. it is my phones SD card Please Help Quick!
I would turn off the laptop and gently use a pair of tweezers to extract the SD card. Make sure that the laptop is completely off or you could short circuit something
May 18, 2011 | Computers & Internet
I put one of those sd adapter cards in my pc's sd slot now it wont come out, my 1gb cards come out just fine but not this micro sd adapter card, IT'S STUCK
check if the lock and unlock switche is the one cozing the problem,it might be stuck some where/on somthing, inside the sd, cz mabe u pushed to hard when pluging it, or the sd is not compatable....
Jan 05, 2010 | SanDisk 2GB microSD Memory Card
SD adapter card stuck in slot
A pair of tweezers or a pair of pin nosed pliers will help you out in this case, just try and grip the end of the card and gently pull it out.
Good luck.
Aug 30, 2009 | Fuji Cameras
Nikon D80 SD Card slot problem
Is it slightly thicker on the contact end, Or is something stuck on the flat corner? try getting a needle and picking out any plastic that could be stuck there. Is the card under warranty
Sep 09, 2008 | Nikon D80 Digital Camera with 18-135mm...
Stuck sd card
take battery pack out ... very very gently with a small screw driver inside battery port apply pressure to lower section of housing to sd card. should pop up when normal pressure is applyed to extract ... worked for me :)
Jul 10, 2008 | Panasonic DMC-FX07 Digital Camera
SD Card stuck in Canon digital camera
I HAVE HAD THE SAME PROBLEM. MY FRIEND LENT MY SD CARD PUT IT IN HER CAMERA IT POPS UP BUT IS STUCK. REALLY ANNOYED AS I NEED MY CARD!!!! PAID £80 FOR CARD AS WELL
Feb 16, 2007 | Pentax Optio S50 Digital Camera
Jensen Vm9414 Car Video Player Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
