Question about 2003 Taurus & Mercury Sable Factory Wiring Diagrams
How to fit windscreen washer hoses for a ford mercury sable 3L 2003
Replace washer hoses
  • Ford Master
  • 694 Answers
They just run under the hood off the passenger side strut hope u can see it they usually bust off right there but if you look hard enough you will find it regards Chris
Posted on Feb 19, 2016
2003 mercury sable code p1151
C1145 is a ABS code and the rest can be explained and possible causes on this Ford website. Ford and Mercury are the same, so it applied to yours too.
Feb 07, 2015 | 2003 Mercury Sable
How to remove a power steering pressure hose on a 1999 Mercury Sable
You have to discon the battery cable before you start. Remove the coolant expansion tank. Remove the drivebelt and alternator if you have an OHV V6. Raise the vehicle on jack stands. Place a drain pan below the pump. From below, remove the splash shield and discon any brackets or ties that hold the hose to the body. After draining, you may have to replace the pwr steering fluid filter, located in the fluid line, then replace the fluid. A crows-foot wrench may be necessary to remove some hose fittings. This is a job for a mechanic with a power lift to be honest. Whatever you do, be careful not to contaminate the power steering fluid. Bleed the system after replacing the hose. The pressure hose is held in place by threads and not a clamp as the other hose has. Get yourself the Haynes repair manual 36075 '96 thru 2005 Ford Taurus & Merc Sable. It has a detailed step by step description of this procedure. Good Luck
Dec 28, 2014 | 1999 Mercury Sable
2003 mercury sable blows cool air when heater is turned on.
Most likely it is a clogged heater core. Have your heater core reverse flushed or your blend door is stuck open.
Oct 10, 2014 | 2003 Mercury Sable
2003 Sable engine change
check the location of the cam position sensor. if they are in the same place ,then use all the sensors from the old motor
Jan 09, 2013 | 2003 Mercury Sable
Will a 3.0L DOHC Duratec 30 V6 from a 2000 Sable fit in a 2003 Sable?
how do i change my DPFE sensor on my mercury sable 2000 .
Need to know the fuse box diagram, what fuse pertains to the wipers... the wipers quit today and I do not have the manual. I opened the hood and see the fuses etc, but have no idea which one is for the...
fuse panel in car on driver side by left knee under dash
Visual Inspection Chart
Mechanical Electrical
  • Wiper linkage
  • Washer nozzles
  • Washer pump hoses
  • Central junction box (CJB) Fuse 211 (15A), Fuse 215 (30A)
  • Multifunction switch
  • Rear window wiper switch
  • Wiper run/park relay
  • Wiper high/low relay
  • Windshield wiper motor
  • Windshield washer pump
  • Rear window washer pump
  • Circuitry
  • Battery junction box (BJB)
  • CJB
  • Generic electronic module (GEM)
Dec 11, 2009 | 2003 Mercury Sable
2003 Mercury Sable headlight bulb replacement
This problem is now resolved, thanks to a prior post by sableowner.
http://www.fixya.com/cars/t1479995-2001_merc_sable_headlight_replacement
The 2003 Sable has the same headlight assembly and removal/replacement instructions as the 2001 Sable. Once I had this information in hand, bulb replacement was easy.
Jan 10, 2009 | 2003 Mercury Sable
2003 mercury sable, not idleing right
Can't say for sure but if you take it to autozone they will diagnose it for free. Mine turned out to be a bad coil pack
Oct 07, 2008 | 2003 Mercury Sable
2003 Taurus & Mercury Sable Factory Wiring Diagrams Logo
22 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
