Question about Intel Computers & Internet
POWER ON WITH BLACK SCREEN - Intel Computers & Internet
Screen is black
If you're getting just a flashing cursor on a black screen it's probably a motherboard/video card/hard disk problem (probably motherboard).
If there's not even a flashing cursor - just a black screen - you can add a failed power unit to your list of problems.
The easiest way to check is to borrow a power unit and video card from a friend's computer. There's no need to remove your existing power unit. Simply disconnect the power cables from the motherboard and connect the spare power unit in its place.
If your computer powers up it is obviously a faulty power unit to blame. IIf there's still nothing on the screen, power down the computer and replace the video card with the spare one. If there's still nothing on the screen when you power it up then in all probability your motherboard is history
Nov 29, 2013 | HP Computers & Internet
Dell inspiron e1545 screen goes black when using battery power
If the battery is good, mine died after 4 years, check the settings in Power Options, look for dim when on battery power. Increase the % to Max or 100%. see what happens. Still have problem consider replacing Battery.
Oct 29, 2012 | Dell Inspiron Computers & Internet
Screen is black will not take pictures
If screen is black you have 2 situations: camera is power on or power off. If its power on and screen is black, its very possible to have something defective inside on the cam microcomputer board or with the display block, and my suggestion is to get to a repair shop for a test or if you are still in the grace period from the manufacturer, to ask for a free investigation. Cheers (PS sometimes black screen occurs when the LCD inverter is gone)
Dec 09, 2010 | Canon PowerShot A400 Digital Camera
Black Screen!
perform power drain. take out the battery and unplug the power adapter. press and hold the power button for 30 secs. put the battery back in and plug in the power adapter then turn on the computer.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
May 03, 2010 | Computers & Internet
On power on, screen comes to life for 1/10th sec, then dies. Power supply seems to be from Benq.
i just repaired a HP1955 monitor,the symptom was: when you power up the monitor,it shows on screen a desktop,but after a sec is screen going black..this repeats continously...
i just resoldered the AC cord connector on power board and also the impulse transformator...now the monitor is running good..
sry for my english,im from Slovakia
Dec 22, 2009 | HP L1955 19" LCD Monitor
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
BLACK SCREEN WITH POWER TO LAPTOP
O n most dell laptops right at the base of the screen is a panel that pops off. If so there is a small card about 1-2inches wide ans 3-4 inches long. It is above the keyboard. this is an aux. power board and should have a connection on it to help power the screen. If this model dosent have this poard than the built in screen cooler is bad and you will have to replace the whole screen.
Aug 28, 2008 | Intel Motherboard
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Computers & Internet Logo
61 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
