SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
SOURCE: swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Posted on Jun 14, 2011
Jun 06, 2015 | Swisher 60 in. 14.5 HP Briggs & Stratton...
Jul 16, 2014 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Jun 02, 2014 | Swisher 44 Iinch 11.5 Hp Trailmower...
Apr 16, 2014 | Garden
Mar 29, 2013 | Swisher Garden
Sep 21, 2012 | Swisher 60" 13 Hp Trailmower #T1360h
Aug 17, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
