Question about HP PSC 1315 All-In-One InkJet Printer
Hp psc 131o deep clean - HP PSC 1315 All-In-One InkJet Printer
Printer was printing fine on my document that includes colorful, heavy coverage of ink. But all of the sudden the printing has lines through it that look like barcodes. They aren't in black, but are in...
sounds like your print head needs cleaning
make sure you have ink in the cartridges
open up your printer properties and look for a maintenance section and choose head cleaning
print a test page to comfirm that the head is clean
some printers need a deep cleaning
when the test page comes out without any imperfections, it should print fine.
Aug 22, 2011 | HP PSC 2410 All-In-One InkJet Printer
Removed out the empty cartridge ans instaled the new one but printer works normally but the print very very light
Print a few test pages, the ink basically needs time to saturate the system.
Perform a deep clean of the ink heads to get it working well, this option is found in the software that came with your printer.
Take care!
damnor01
May 07, 2011 | HP PSC 1350 All-In-One Thermal Printer
My printer is printing in purple both pictures and text.
Most likely you need to do a deep cleaning of the print head nozzles. Found the following info on ehow.com. It's not your exact model but may lead you in the right direction.
Click on "File" and then "Print" if your printer is an HP 5420v or a 5440 or if it is a 5490 series. A print dialog Box will open. Click on "Properties" and then select the "Service" tab. Open the printer toolbox by clicking on "Service this device." When the "Service" tab appears, click on "Clean the print cartridge." A series of easy-to-follow instructions will appear. You will be allowed up to three levels of cleaning if your print head requires it. Be prepared for your printer to automatically print a test page after each cleaning level--if a test page looks O.K., you can cancel further cleaning.
When this happen to me I did a deep cleaning and it cleared right up.
Oct 13, 2009 | HP PSC 1610v All-in-One Printer
HP psc 2410 photosmart all-in-one not piking up paper
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 16, 2009 | HP PSC 2410 All-In-One InkJet Printer
Continual error message on printer after replacement of new cartr
Try running deep print head cleaning on the printer and see if that helps
Apr 10, 2009 | HP PSC 1350v All-In-One InkJet Printer
Test Page
Go to the printer settings through the software given by HP, probably HP solution centre and choose printer settings and further you can go deep to disable the test page at startup.
Thankyou
Jun 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer installation
Download the drivers from here if you don't have the cd to run.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=hp+psc+1400
Just select your printer and operating system and go.
Hope this helps. Good luck.
Jun 07, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
