Question about Jobar International Inc Multi Purpose Garden Roller JB5582
I need a new plastic roller that the large foam piece fits on
How can I make the most of my new foam roller to strengthen my lower back?
Read this article from the Livestrong site - it has some good tips about using a foam roller for your lower back http://www.livestrong.com/article/344855-how-to-foam-roll-your-lower-back/
Sep 10, 2012 | Exercise & Fitness
Where can I buy a half round foam roller online to use while I am doing Yoga?
There are a few places to purchase foam rollers online - you could also go to a local sports store near you. The first link is the brand that I bought, and I found it here for even less than I paid.
http://www.amazon.com/Foam-Roller-Half-Round-Black/dp/B000VK1YM2
http://www.amazon.com/fit-Half-Round-Foam-Roller/dp/B000TQ9GR8
http://www.gaiam.com/product/spri+half+round+foam+roller.do
Aug 20, 2012 | Exercise & Fitness
Are there different types of foam rollers or a standard kind in different sizes?
There are in fact several types of foam rollers: low density, molded foam, EVA foam and grid foam rollers.
What is a foam roller?
A foam roller is a cylindrical piece of foam - picture one of those foam noodles that kids play with in pools, only these are slightly thicker and larger in width. Here is an image of a typical foam roller -
Hello My boyfriend has a Konica Minolta Magicolor 2350 printer. I just replaced opc drum for him. When he switched it on after this he says there was a bang and then the message Service call 08. He...
Hi Amanda,
Wow your so sweet to your Boyfriend, anyway try to check on this manual im very sure that something is misalligned on the drum.
http://www.inkcloners.com/Service-Manuals/MagicColor-2300-manual.pdf
Hope this gives you guys an idea..
Cheer up and dont forget your THumbs Up...
Thanks!
Mar 17, 2011 | Minolta magicolor 2350 Laser Printer
The brush head spins slowly
May just be in the connection between the two rollers. I know it looks like one roller, but it is actually two pieces. Remove the silver bottom plate, turn the two large plastic screws on the top ends of the roller assembly, they do not need to be removed, and the two end caps will pop off the roller. you have a short roller and a long one. Where they go together under that black round piece is where you will look, there is a silver shaft sticking out of both sides. then look in the ends of the rollers where they connect to the shaft and look for signs of wear, they are rectangular and sometime they will get rounded out and can not turn. Also at this time you can turn on the vacuum and make sure the motor is turning those shafts. If it is turning fast then those ends of the rollers that fit in there are probably worn or maybe just one of them like mine did. Parts are available from Dyson or maybe Sears etc. You may just want to get a whole new roller if this is the problem. The only other issues may be the motor or the gearing that is under that housing. You will have to remove the other clear plastic piece to access this area. Take care and good luck with it..
Mar 09, 2011 | Dyson Vacuums
Jacuzzi sent me new rubber gasket for attaching flapper assembly to tank-(held in place with a large white plastic nut) Does the totally flat side of the rubber washer face the tank or away from the tank?...
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Aug 31, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Texas Instruments TI-5045 SV paper won't advance
The foam on the feed roller is probably decayed/ soft. Which has caused the plastic gear that engages that drive gear to wear. If the gear is moved/ spaced over to pick up the 40% that isn't trashed - it'll feed.
I'm going to try to fix my Goodwill purchase anyway. Anything is better that the Canon piece of rubbish I have now. Mybe someone can tell Canon that a few months of use is not enough?
-Sano-
Oct 03, 2007 | Texas Instruments TI-5045 SVC Calculator
Jobar International Inc Multi Purpose Garden Roller JB5582 Logo
Top Jobar Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Jobar Garden Expert? Answer questions, earn points and help others
