I have sony KV-DB29M60 problem is colour Blue missing just like is in NTSC mode & picture is perfect B/W. pls. suggest
ladywinn
  • 5138 Answers
SOURCE: Picture and sound went out suddenly on a Sony KV-35S40
sony has problem with bad picture tubes as well as flyback transformers .if you have shorted hori output then replace it if set shorts it out again your looking at bad flyback transformer as well as maybe leaky tube.
Posted on Jan 17, 2008
jerryg50
  • 1667 Answers
SOURCE: KV-28CL10U colour circles
There are two things that commonly cause the fault that you are describing. Below is the main one.
It is very possible that the degaussing circuit or the degaussing coil is no longer working. A common fault is that the degaussing thermosistor has gone defective and the CRT has become magnetized. The earth's magnetic field along with other environmental things cause the CRT's internal mask to become magnetized over time.
The thermosistor in most Sony TV sets is located in the power supply area. It looks like a little black square box with 3 solder posts on it. In some models it has 2 solder posts. After a number of years this part may fail.
When the power is first turned on, the thermosistor is very conductive. After it heats up, it goes very high in resistance. It drives a high decaying AC mains current through the degausing coil (located around the shroud of the CRT assy) for about 50 to 60 ms. It then allows the current to decay to zero over the next 50 ms. When you turn on the TV set, you normaly hear a kind of a loud thump noise. This is the degaussing action.
Once the degausser is serviced and is working properly, it may take a number of power cycles to eventualy demagnetize the CRT. After shutting off the TV, it takes about 20 minutes before the degausser can work again. The thremosistor needs some time to cool down.
If you are not experience and trained for doing TV service, I would suggest you give the set out to an experienced TV service tech to change this part. There are serious safety issues when working inside of TV sets.
It is possible to purchase a manual hand held degaussing coil. There is a proper procedure for using this type of coil. If you were to manualy degausse your CRT, you would have to do it on an almost daily basis. The manual degaussing coil is fairly expensive to purchase. It would be better to service the set.
The second thing that causes the CRT to show colour purity problems (color splotches, or circles, or patches), is that the mask inside on the face of the tube has become dislodged off its supports or became warped. This can happen if the set has been dropped, or hit hard enough to do some damage to the mask. I have seen this where TV sets were roughly handled during moving them.
The only fix for a damaged CRT mask is to replace the CRT. The cost would be as much or more than the set is worth. This is if you can even find a replacement CRT. Most all of the manufactures no longer manufacture replacement CRT's for consumer products.
Only specialized CRT's are still being produced on a limited bases for specific industrial and military equipment that must still be kept in service. These are for some types of radar, medical, aerospace, and other related industries.
Jerry G.
Posted on Apr 16, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KV-BZ212N50 schematic diagram
Service Manual of KV-BZ212N50 is available on charge basis.
Posted on Jul 29, 2008
SOURCE: Sony Trinitron TV that's about 14 years old
on your sony tv (not cable) remote - hit the MENU button, then scroll right to SETUP on the screen - the first choice - caption vision - is probably set on a close caption or text - change it to off. i had the same problem - would pop up occasionally and only on certain screens. this fixed it. hope it works for you.
Posted on Nov 03, 2008
  • 4234 Answers
SOURCE: Missing Green colour on 36" Sony FD Trinitron WEGA
This is not a problem that a reset will fix. THe 5 blinks is a code that indicates a problem with the AKB circuit. There is a possibility that the picture tube is starting to fail, but that is rare. If you are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, let me know and I will provide additional details and instructions for a couple of repair options.
Dan
Posted on Feb 24, 2009
Sony kv-EF29M80 blue colour missing and takes time to turn on unlike how it was before. the images are blur.what could be the problem and what solution is there for it?
Check the collector voltage of blue output transistor at its video output board, which can be located directly plugged onto the neck of the picture tube. Check for any loose solder terminals at this board.
Dec 04, 2012 | Sony KV-32FX60 TV
Sony KV-40XBR700 40" CRT WEGA
I too would like to know the solution to this question...we are having the identical problem and Sony doesn't seem to know how to fix it. Although, the picture from the DVD player is perfect, the pictures for cable & video games are terrible. Very frustrating!
Aug 24, 2011 | Sony KV-40XBR700 40" TV
I am only getting black and white pictures when using the sony dvd -DVP-SR200D when hooked-up to tha TV
Change your tv colour System in to Auto mode.It will adjust in menu.Mostly DVD recorded on NTSC 3.58 colour system.After adjust on auto mode Colour will come.
Oct 30, 2010 | Sony DVP-SR200P DVD Player
Kv 27ts27 set works fine except lost color. now black and white
pls check and selact in your tv colour system PAL / NTSC / AUTO
set Auto colour system is Best .
set chennal Auto serch
if not
then problum is in side tv pcb. so repare pcb with nr. thech.
Oct 30, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Lost sound on my GE (Thomson)46GW947X1
pls. first open your tv menu and select sound & colour -sys see the sound-sys / colour-sys is maching with your country transmitiongh sys {EXP.: PAL-BG / NTSC-DK /NTSC- MN /SCEAM- I ) IF your not set purfictly pls select AUTO colour sys and set automaticly set colour & sound .[see user's menual book and set your tv.]
Oct 06, 2009 | GE 35GT695 TV
Sony trinitron only in blacka nd white. how do I return it to colour?
pls check your tv colour system it is not maching with your country col-sys [PAL /NTSC/SCHAM] so pls open menu and set col-sys select any one or set col-sys is AUTO see the colour pictur.
* NO colour [B&W} pictur
[1] cabel singnel is wek.Pls. check cabel canaction re set pin or cabel canaction.
[2] pls tune ch. set Auto serch or fine tune to set ch.
if not colour pictur then problum is inside of your colour tv set.
Oct 05, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
DVD player only plays in black and white
dear,
there must be some options either in tv mod or in dvd, is not properly selected..
check both manual in details...
regards,
dont forget to rate
Aug 10, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KV-24FV12 picture problem
Alright, TV has hardware problem in Horizontal section and I would suggest to set Picture Quality as Soft Mode.
Jun 20, 2008 | Sony KV-24FV12 24" TV
Poor quality picture while playing ps2 games?
i think you should try other modes too like pal and others or in many tvs there is a option auto so the tv automatically select the best mode of color itself.....
Jan 20, 2008 | Sony PlayStation 2 (PS2) Console
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
