Question about Casio Watches
Old casiotron battery died, replaced but watch still does not work In the manual is says not to leave old battery in as can cause malfunction. unfortunately I left it in! Any ideas?
4 Suggested Answers
  • 373 Answers
SOURCE: Replacement battery for Philippe Starck Fossil watch
can you check on web site
Posted on Jan 31, 2009
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Posted on Feb 10, 2009
  • 4 Answers
SOURCE: beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
Posted on Jun 12, 2009
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Aug 16, 2014 | Casio Watches
My wenger sport elegance chronograph watch stopped working after 2 months. I bought it brand new. After readjusting the time, it worked for about 8 more hours, and then died again. The small dial on the...
You should change the battery, it is the cheapest thing to try. The batteries can be very old before they are installed and could have been in the watch a long time before you got it.
Sep 30, 2013 | Wenger Sport Elegance Chrono White Dial...
Have replaced the battery several times & works for a few days then dies again - what could be wrong? Seiko SUK008
In my experience the most common cause of fast discharge of a battery or a capacitor is a gummy or dirty gear, which cause a much heavier electric load on the battery. Causing it to fail too soon.
Some watches are simply poorly oiled. Others are poorly sealed so moisture or dirt gets in.
I would recommend a simple cleaning and oiling. Very often that will make your batteries last much longer.
Apr 04, 2013 | Seiko SUK008 (Size: ) Watch for Women
We purchased a Casiotron R-11 watch, model number 54194. After many years the battery has gone flat, we replaced this but are not too sure how to set the time and date etc. Please can you...
Hey there, Setting the Time on the Casio R-11 until the R-15 ist quite simple: insert the Battery, the you should see the seconds counting on the top of display- depending on the model there are bars or squares blinking every 5 seconds and progressing until one minute is done, then it starts again. When all the bars for the seconds are filled, simply press the button located on the left side of the watch. You can press it by using a pen etc. Now the Hours start running, let proceed until the right time is displayed (notice the a.m. or p.pm. bar on the top/right of the display). When you reached for example 10 (for 10:00 in the morning or night), then you push the select button on the right,then same procedure with the minutes. When you finished selecting the hours and minutes press the button on the right again and the watch starts with the time with 0 sec. You cab set the date by pushing the select button on the right and simultaniously pushing the button on the left with a pen.
Hope it works out
May 05, 2011 | Casio Watches
Bulova accutron 2 years old stopped running after jeweler replaces battery. You could hear a hum but it quit working. Cost to fix?
The first thing I would do is take it to another jeweler (preferably in a higher end store), ask how experienced he/she is with your brand of watch, find out if they are the senior jeweler in the shop and just get a feel of whether you trust their opinion or not. Explain to them what happened and ask them if they can tell whether or not the person who changed the battery for you could have caused the damage to your watch. If they confirm that the person who changed it likely or certainly caused the damage, ask them to write a note explaining what the original jeweler did to cause the malfunction and then call the jewelry shop and tell the owner what you have found out. If they get huffy with you and tell you to buzz off, you have to then decide how much trouble the watch is worth. You can always take them to small claims court, but most shops will back up their work and if you have solid proof that their employee screwed it up and you don't let them back you down, they will likely (eventually) make things right for you. Best of luck!
Jul 02, 2010 | Watches
End-of-life indicator for Victorinox Night Vision II watch - I seemed to remember that the watch battery can be monitored through the red LED that blinks every 10 secs. when it is OK, if the battery needs...
Not a malfunction - just a dead battery. See the manual:
http://www.victorinox.com/medias/sys_master/timepieces_manuals/8800396705822/NightVision_II_ENGLISH.pdf
May 12, 2010 | Watches
Do as folloes:
Feb 09, 2009 | Relic 0504648FA
Watch won't run
It is quite hard to fix your warch as it was left for a prolonged time with an old battery in it. This usually causes contact oxidization and sometimes an integrated circuit shortcut. I'm sure that that the movement in your Timex can be replaced as manufacturers usualy keep producing updated versions. Find the decent watchmaker in your area and ask for movement replacement, not repairs.
Expect to pay GB 20 - 30, as movement prices vary and watchmakers job is very skillfull and takes alot of time and patience, respectively it isn't cheap.
Probably the watch itself do not cost that much, but you are paying for very skilled work and at the very end you will get back your precios watch in a nice working order- all this depends on how much you like it.
And the last thing: Don't be fooled by name 'movement replacement', as except this,watchmaker must clean and polish case and bracelet (glass as well if it is made of plastic). New battery is a must as well as testing for correct timekeeping.
Hope this will help.
P.S. Next time you decide to leave your watch without attention for years- take the battery out. Then it will be safe even for 100 years.
Regards
Arthur
Dec 02, 2008 | Timex 27191 Wristwatch
Light
My watch had the same problem and i could never figure out what it was so i just lived with it for a couple of years. then, just recently even when my watch was getting plenty of sun the battery would die in the evening and shut off at night. so i replaced the battery and evrything works great. even the light which leads me to believe the solar panel is just a gimmick. i have an old g-shock watch that i bought in 1989 and it still works and is on the origional battery. my gw 300 is about 5 years old and needed a battery. i guess 5 years on a battery is prety good but i would rather have it last for 19 years like my old one.
Jan 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
57 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
