Question about Friedrich ZStar ZQ10A Air Conditioner
Friedrich a/c zq10 thermostat won't kick in
My Friedrich thru the wall a/c unit only blows air. Once in a while cold air comes on. Can it be the thermostat? Is it hard to change?
Thanks for any help.
Bill
  • wimarti Jun 18, 2009
    Tom;
    Thanks so much for your advice. I'll probably look at it this weekend and let you know how I made out.
    Thanks again. Bill
    Sergeant:
  • 340 Answers
Likely is the thermostat or could be the compressor going out on over load compressor runs blows cold air trips out on the over load fan will stay running jumper out the thermostat see if it stays running.like1/2 hr. if it does replace the thermostat not hard to change if you can find one.Tom
Posted on Jun 18, 2009
Ac unit will not heat
You need to check your model # a CP06 is a straight cooling window unit you may have an EP08G10 this is a heat cool unit. Double check your thermostat is turned to higher setting. If so you may have an issue with the heating element or the heat limit on the element.
Dec 08, 2013 | Friedrich CP06C10 Wall/Window Air...
Thermostat friedrich twintemp
try unplugging it from wall and try to reset, power outage might have caused a capacitor to fail
Aug 27, 2013 | Friedrich EL25L35 Thru-Wall/Window Air...
Describe your KS15L10 Thru-Wall/Window Air Conditioner Problem My unit also runs about 10 minutes and the kick off the 15 amp breaker. Unit was purchased 2006. Any ideas
Hello my name is Heath iot will be my pleasure to assist you. The first thing to do is unpludd the unit then go out side wioth a garden house and use a strong jet of water and blow it through the coil and get it real clean if you can then try running the unit.
Aug 29, 2011 | Friedrich QuietMaster KS15L10...
I have a Friedrich thru the wall air conditioner with a wall mounted thermostat but I cannot seem to regulate the temp. with the thermostat. What happens when I press the up and down arrows.....does the...
It is not uncommon for the room temperature and the set temp. on the thermostat to be several degrees apart. The room temperature should go down when you set the temperature on the thermostat down to a lower number.Hope this helps you and thanks.
Aug 17, 2011 | Friedrich Heating & Cooling
My Friedrich QuietMaster Series KS15L10 115V model will being to blow cold air and then after 5 to 10 minutes will trip the circuit breaker. We recently had a heat wave for about 2 weeks in which the unit...
Hello
Yes the northeast had temps that went past the limits of modern a/c.
Try cleaning the outside fins and coils.
Spray a product called simple green on the fins while unit is off.Leave on for 5 min.
Then rinse off with a hose.
This should keep your compressor running cooler.Also clean any filters in the inside unit.
Aug 03, 2011 | Friedrich QuietMaster KS15L10...
I have two Friedrich PDE15KSB-C units. When trying to turn on the heat neither will kick into the heat mode. They both blow cold air only. When they are first turned on the air blows, and there is a...
Keep +10 degree from your room temp and also thermostat in "heat" . And then check. But in your case, I think RV not energized. If no proper voltage in RV in heat mode, check the wiring to RV. If voltage in means RV not working properly. You have to change RV. Thanks.
Dec 14, 2010 | Friedrich PDE15K3SB Portable Air...
Friedrich Wallmaster is not throwing cold air.
I have the same problem - bought mine 4-5 years ago been suffering ever since - spent so much money on Friedrich and still using fans. Piece of ****.
Aug 21, 2009 | Friedrich M18CF Split System Air...
Squealing and sometimes doesn't blow cool
A squealing noise is most likely the bearings going bad in the blower motor. This will slow the motor down. If the blower is not operating at the proper speed this will affect the temperature pressure relationship of the refrigerant. This will cause the unit to put out the wrong temperature. Running the unit to long under these conditions can possibly cause further problems ( including a very high electric bill). I recommend that use do not use this unit untill it is repaired or replaced.
Good luck.....
May 03, 2009 | Friedrich M18CF Split System Air...
Friedrich ZStar ZQ10A Air Conditioner Logo
265 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
