Question about Orion 2250 Sx Amp Competition Amplifier Hcca Old School Classic Extreme Beast
Wiring diagram How to hook up amp to stereo and speakers
Speaker wiring diagram for a 08 dodge 2500 truck with 7 speaker infinity
Never have found good wiring diagrams for stereo's. Bought them and color codes didn't match. I have mitchell and alldata at work, they don't match. I wire them in with a volt/ohm meter. I find B+, Then hook ignition the the heater control wire. Ohm out the speakers. Thing is, you have infinity. You'll have to find the amp and cut the speaker wires and patch them there also, first. Just a note.. All speaker wires are twisted/paired wires. Cut the tape back 4 to 6 inches to find them. Another note. The speaker wires from the stereo to the amp will be a set of colors. From the amp to the speakers will be different colors.
Nov 01, 2016 | Dodge Cars & Trucks
How to hook up speakers
Dennis, Check the attached links diagrams,instruction and guides for hooking up speakers. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Connect Stereo System Stereo Barn
How to Set Up Your Speakers with Receiver or Amplifier
amplifier wiring diagram Google Search
speaker wiring diagram Google Search
Aug 16, 2016 | Kenwood Audio Players & Recorders
Stereo wiring diagram for 2005 Chevy trailblazer
Hi there:
Check this on 2005 Chevrolet Trailblazer Car Stereo Wiring Chart...
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 25, 2012 | Cars & Trucks
I have a 92 marquis, and ive just changed out the factory stereo with a aftermarket. How can i hookup the amp that came with the bose system??
If you bought a wiring adapter kit for the aftermarket stereo, the unit should hook up directly to the stock bose system. Note: If there is sound coming from the speakers after installation, the amp IS hooked up...the speaker wiring is routed to the factory amplifier, not the stereo itself, the stereo wiring is just signal leads to the amplifier. In some instances, you may have to connect the amp remote wire to the remote wire coming from the aftermarket stereo(blue wire). I hope this helps. Any other questions, just reply.
Feb 06, 2011 | 1992 Mercury Grand Marquis
Need a wiring diagram for 2002 chev, caviler stereo hooking up aftermarket stereo
ARE YOU AWARE THEY MAKE A VERY INEXPENSIVE ADAPTER HARNESS THAT HOOKS UP TO THE FACTORY HARNESS, NO WIRE CUTING,CAR AUDIO SHOP CAN GET THE ONE U NEED, ABOUT $12. HERE IS THE WIRING COLOR BREAKDOWN OF THE DASH HARNESS.
2002 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does not provide a switched power source. Run a wire from the Ignition Switch.)
Car Radio Illumination Wire: Gray
Car Stereo Antenna Trigger: Pink
Apr 13, 2010 | 2002 Chevrolet Cavalier Coupe
Radio: replacing radio,not stock,have adapter connector, when hooked up radio pwrs up,but NO SOUND,somehow in mute,took to the"radio doctor", radio tests fine,& he saw how I had it hooked up, extra...
YOU WILL HAVE TO TRACE THE WIRES OUT, DO U HAVE A SEPERATE AMPLFIER? MANY OF THESE VANS DO, IF SO THAT IS THE PROBLEM.
HERE IS THE WIRING COLOR DIAGRAM FOR YOUR VAN
1998 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
Right Rear Speaker Negative Wire (-): Blue/White
Aug 06, 2009 | 1998 Dodge Grand Caravan
Here it is! Please rate this info.
2000 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Nov 14, 2008 | 2000 Ford Taurus
Ford taurus
HERE IT IS. PLEASE RATE ME.
2004 Ford Taurus Car Radio Stereo Wiring Diagram
Need to know factory wiring colors to hook up aftermarket stereo
1990 Mazda 626 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: N/A
Car Radio Illumination Wire: Red/Black
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Aug 03, 2008 | 1990 Mazda 626
Orion 2250 Sx Amp Competition Amplifier Hcca Old School Classic Extreme Beast Logo
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
