Satellite receiver manuals - Audio Players & Recorders
Why don't I have satellite picture.
You need to give more information. For instance, do you get a picture when using a DVD/BluRay player, Roku or gaming system of any kind? Are you connecting with HDMI , analog or optical?
Have you tried connecting your satellite receiver directly to your TV?
If so is there a picture and sound? If not it might be the satellite system.
Aug 24, 2014 | Onkyo receiver HT-R667 User Manual
No tv picture when satellite receiver connected to HT-RC370
make sure you have selected all the right av's from the satellite to the receiver and from there to the tv. dont forget to select the input you connected the satellite too
Apr 15, 2014 | Onkyo receiver HT-RC370 User Manual
Can i hook up an old tube type tv to a new high satellite dish? i dont care if i get high def picture just want a regular picture.
Yes there is an option for ouptuting 480i signal from most hd receivers. You will need to check the specifics for the satellite dish receiver as to the channel that the TV should be on as well as how to set it to the resolution that you need. (I know some Dish receivers need channel 60 for the SD TV (coax (RF) connection) when it is TV 2 but channel 3 or 4 for TV 1.) Also check your TV so that you can use the best possible input available.
However, you may not be able to read the closed captions unless you enable them on the receiver. (Apparently, the encoding has changed.)
The manuals for some satellite company receivers are on their website. For example, Dish network manuals are here: http://www.dishnetwork.com/supportsection/manuals . Their manual for the Solo VIP 211k describes connecting the receiver to a SD TV on page 91 (page 97 in the PDF version).
I hope this helps.
(I'm not aware of any satellite system that doesn't use a set-top box. If you do not have a receiver, then the above does not apply and you may not be able to get a signal.)
Apr 13, 2011 | Televison & Video
Im trying to find a manual for a delphi xm skyfi2 SA10101
You can get the manual on the link below. Just school down to product detail then colic on the manual link.
http://www.amazon.com/Delphi-SA10101-Satellite-Receiver-Control/dp/B0006GX0IC
Good Luck please rate 4 thumbs up and please leave a testimonial
Nov 06, 2010 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
I have a XM Model 136-4335. I need an operators manual. I need to program preset stations and don't know how. Thanks, Mike
The XM model number provided is branded DELPHI but is actually made by AUDIOVOX... a manufacturer that is commonly rebranded XM, TERK, RCA, etc. So the Audiovox manual is what you need. Now since Audiovox usually doesnt support directly its hard to get manual from them directly. The link to your manual (the third down on this page and the picture looks a bit diffferent but is the silver receiver not black box ones) Good luck
http://www.retrevo.com/support/Audiovox-XM-Satellite-Receivers-manual/id/395ag115/t/2/
Jun 02, 2010 | Delphi XpressRC XM Satellite Radio...
How do I set up my receiver to connect with my tv, dvd recorder and a satellite box?
First of all read carefully user manual or guide book of receiver Installation. connect all Devices like Satellite TV box, HD TV, DVD recorder with audio video & coaxial splitter cable.
set-up-receiver-connect-tv-104u1fzs1oqkwm1vdgsl0pue-2-0.png For more help
4k TV Home Theater Audio Video installation in Houston
Aug 23, 2009 | Audio Players & Recorders
 Grubhead
Grubhead
