Question about Bose SoundDock Digital Music System for Apple iPod - White
My ipod is playing music when put into my bose sounddock but there is no sound
When I place my ipod in the sounddock, it plays and charges but there isn't any sound.
3 Suggested Answers
SOURCE: Bose Sounddock - Speakers have a loud hiss at low song volume
Here is how I fixed the hissing noise in my Soundock;
--Pull the bottom plate off (It is attached by 4 screws)
--There is a green motherboard with 2 ribbonwires. .
--One of the ribbonwires (the one the mounts the ribbon vertically) had loosened up.
--Use a tweezers to pop it back into place and that noise will disappear.
This is a design flaw, as the action of inserting/removing your ipod, coupled with the action of setting your sound dock down will work this ribbon loose.
Posted on Aug 21, 2009
  • 6771 Answers
SOURCE: Bose sounddock no longer playing music
The problem is in the Bose sounddock, there are no authorized service centres other than Bose, all repairs are done on site and they carry the parts.
Posted on Mar 08, 2012
The problem is with all those little electrolytic capacitors. They look like little cans. There on the middle board. What happens is they dry out just like batteries. I fixed one for like 7 dollars plus shipping from Digikey. If you want you can use an ESR meter to check them, but don't bother. The Circuit board is the middle board. Not the board that has the connector that the ipod plugs into, or the board the speakers plug into, its the one in the middle of the two. Yes you can charge your ipod but it won't play music. Also check all the pins on the connector that the ipod plugs into, sometimes the solder joint breaks and needs to be soldered.
Mar 07, 2012 | Bose SoundDock Digital Music System for...
My ipod wont play in the bose sounddock. tried shutting off the ipod. dont think my sounddock has an on/off switch. did unplug all pieces
We have an HCL desktop computer. Though we had loaded Ac97 Sound Driver still the sound is not coming (totally soundless) Can you suggest what to do?
Jan 16, 2011 | Bose SoundDock digital music system...
Ipod charges on bose dock but won't play ipod firmware 3.1.2 recently updated
i have bought a ipod nano and i want it to work in my car stereo it charges but does not play it does play my sons ipod touch so the cable is ok
Feb 07, 2010 | Bose SoundDock digital music system...
Bose SoundDock burned out two of my iPods - a Nano and a classic.
um ur sounddock might require that u place the white docking piece that came with ur ipod to be place b4 the ipod is docked if not u may ruin the dock and the ipod usb port this is done because different generation ipods(nana and touch and ...) have different shapes so the entrance for docks may require to be eleveated or reduce in gradient basically if the dock isnt made for the specific ipod or u dont know just put the white piece in
Oct 04, 2009 | Bose SoundDock digital music system...
Bose Sounddock won't play iPod touch
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Sep 13, 2009 | Bose SoundDock Portable Music Pack Docking...
Won't charge on Bose SoundDock
You're not doing anything wrong. Newer iPods and the iPhone require accessories that were specifically designed for them. For example, the iPod interface in my car will not charge my iPhone, however, I can still play music through it.
The only solution is to: 1: Buy a SoundDock II or 2: Charge your ipod seperately.
Apr 20, 2009 | Apple iPod touch
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
My iopd won't change songs when playing on the bose
Reset your Ipod. Go online to troubleshoot your ipod. I had the same problem and resetting the ipod fixed it.
Dec 25, 2008 | Bose SoundDock digital music system...
Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Dec 09, 2008 | Bose SoundDock digital music system...
Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Sep 17, 2008 | Bose SoundDock digital music system...
Bose SoundDock Digital Music System for Apple iPod - White Logo
32 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
