Question about Cooktops
How to unlock Lofra induction cook top - Cooktops
4 Suggested Answers
  • 906 Answers
SOURCE: induction cook tops
good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
sodeep
  • 3267 Answers
SOURCE: how to un lock my GE Profile Induction cook top?
Try turning off the breaker for at least 10 min and re apply power. If this doesn't work, then there's an internal problem.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
Posted on Nov 15, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: error message on my electrolux INDUCTION STOVE TOP
    Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
    Posted on Nov 02, 2012
    Gaggenau 200 Series?
    If it is similar to the VE260 model, this induction type of cook top is very old. 22 - 23 years if it came with the home when it was built.
    I can only offer basic suggestions of which you already probably know.
    These induction type cook tops rely on the pan or skillet to be magnetic like stainless steel. If the bottom of the pan has any buildup of residue, this will dramatically reduce the efficiency of the unit.
    If the pans are immaculate, then the electronic elements that produce the magnetic induction to heat the coils must be weak. As old as the unit is, it is probably not feasible to have 3 of the elements repaired....
    A new top can be purchased much cheaper. Consult Consumers Reports for unbiased product reviews for your best reviews. As a final suggestion, find someone who is qualified to use an electrical multimeter to read the current on both sides of the power receptacle to ensure that your voltage is 230V. A loose connection on the receptacle can cause the elements to have the same result.
    Although I can imagine you have already done everything above, I just wanted to send you what I can offer.
    Jan 02, 2014 | Gaggenau Cooktops
    Induction error e6
    Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
    May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
    Error message on my electrolux INDUCTION STOVE TOP
    Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
    My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
    You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
    Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
    Induction cook tops
    good day,
    kitchen appliances
    Sep 14, 2008 | Dacor Millennia ETT304 Electric Cooktop
    Burn fuses
    Something inside is short-circuited. All components look fine thans to burned fuse. Don't try it anymore with new fuses. You need to get a repairman to check it out.
    Apr 02, 2008 | Sunpentown 11 in. SR-1330 Electric Cooktop
    Cooktops Logo
    349 people viewed this question
    Top Cooktops Experts
    Paul Carew
    Are you a Cooktop Expert? Answer questions, earn points and help others
