Question about PfaFF Creative 7570
Pressure foot lefter broken on a mofel 844 deluxe zig zag sewing machine
kent581
  • 87 Answers
SOURCE: it will not do zig zag
Is the machine older? If it is, it could be sticking. Try using sewing machine oil on it. Put it in Z.Z. mode and try to wiggle it left to right.If it will go back and forth but sticking oil it for sure SEWING MACHINE OIL ONLY. not 3n1 oil Turn the handwheel one rotation and try to wiggle it left to right again.
Kent
Posted on Mar 23, 2009
  • 632 Answers
SOURCE: I took my machine to be 'cleaned', and when I get
Independent repair shops will work on any model, it's the parts they have no control of. The good thing is that we have ebay, where most hard to find parts always pop up. All or 95% of sewing machine stores here in Bay Area Ca. sell and service PFAFF, even vintage metal mechanical models.
Posted on Jun 19, 2010
bugoy31
  • 1238 Answers
SOURCE: The zig zag is not working on my machine. It
Good day!!!!
Please try this simple procedure to fix your problem:
    • 1. Read through your sewing machine manual and make sure that you have the correct settings for sewing a zigzag stitch. Set the proper stitch length and width as instructed.
    • 2. Try some of the simple things first. Remove the bobbin plate using a screwdriver and then remove the bobbin. Clean out any lint that may be under the bobbin and which may cause your zigzag stitch not to work. Replace the bobbin and the bobbin plate and test your zigzag stitch.
    • 3. Follow the directions in your sewing machine manual and oil the components of the sewing machine that rub against each other, as a lack of lubrication can prevent your needle from moving back and forth.
    • 4. Reset the timing, which affects how your presser foot and feed dogs work together, by adjusting the cam of your sewing machine. Look at your machine's manual to find the exact location of the cam, usually at the back of your sewing machine. Loosen the screws in the cam and turn it clockwise to increase the speed or counterclockwise to reduce the timing.
    • 5. Check the tension on your sewing machine, as too much tension may pull the threads too tightly and loose tension may not pull the threads tight enough. Set it at the middle range and test it from there, trying to make a zigzag stitch using a greater or lesser tension.
    • 6. Take your sewing machine to a professional repair shop if you have tried all of the other steps and still cannot sew a successful zigzag stitch.
I hope this information will be helpful...
Thanks for using fixya..
Posted on Sep 20, 2011
  • 574 Answers
SOURCE: pfaff squeaks
spray linkage with wd40
Posted on Mar 22, 2012
SOURCE: Pfaff 362 won't zig zag
yes, it's very possible that the control/knob needs to be replaced
or the cam or gear that works the zigzag
Posted on Jun 05, 2012
How can i find a manual for a universal sewing machine kzm 022951
Universal Sewing Machine Product Support ...
www.manualsonline.com/support/universal/sewing-machine/
Just aquired a universal sewing machine model Kzm. Universal Sewing ... Needmanual for Universal AZZ Super Zig Zag sewing machine. Universal Sewing ...
Universal Zig-Zag Deluxe sewing machine w/ manual ...
? 4:06
www.youtube.com/watch?v=ZWmBB6za9-s
Oct 28, 2013 - Uploaded by hindsight80
Universal Zig-Zag Deluxe sewing machine w/ manual. I just cleaned and oiled it it is ready to go. Awesome ..
Nov 05, 2015 | Sewing Machines
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
Dressmaker zig zag deluxe s3000 doesnt pick up bobbin thread
it's possible that a gear is broken or worn a sewing machine shop can tell you exactly
Feb 20, 2012 | Sewing Machines
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
What foot should I use for basic stitch or zig-zag stitch?
a all purpose foot or a zig zag foot will do both straight stitch & zig zag
Dec 16, 2010 | Singer Sewing Machines
I cannot get my tension adjusted correctly. I have lost my manual. Can you give me some help. Also, do I need a separate foot for the zig zag stitch.
usually a tension of 3 or 4 is good
only if the presser foot not is not made for zig zag--all the presser foot's that I've seen on new machines do straight stitch & zig zag,, if the opening in the foot is large then manually try a zig zag stitch to see
Nov 22, 2010 | Brother XR-65t Mechanical Sewing Machine
Sewing Machines Logo
14 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
