Question about Westinghouse Electric LD4655VX TV
Ld6455vx scan code - Westinghouse Electric LD4655VX TV
ABS light is on but scan tool does not pick up an error code
Is it a code reader or a scan tool ,there is a difference ! An some will just read OBD codes from engine control module . You need to take it to someone who's scan tool can check all modules on the vehicle . Then again in some situations the factory scan tool will only work ! Everything You Need to Know About Scan Tools with John Anello
Sep 01, 2015 | Cars & Trucks
How to fix canon mp258 error code 2,140,2 when i scan douument
please help me....
I m trying to scan my document but it is showing error code 2,140,2 on PC and error code E5 at printer....my catridiges is empty is it because of that reason............
Aug 11, 2012 | Canon PIXMA Office Equipment & Supplies
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
Code 463 fuel level sensory high imput, what is this and where is it located
Not sure if this helps or not, but here is information from the 1998 Jeep Grand Cherokee Service Manual, ezg_25.pdf, page 6 of 20…
Hex Code = 95
Generic Scan Tool Code = P0462
DRB Scan Tool Display = Fuel Level Sending Unit Volts Too Low
Description of Diagnostic Trouble Code = Open circuit between PCM and fuel gauge sending unit.
Hex Code = 96
Generic Scan Tool Code = P0463
DRB Scan Tool Display = Fuel Level Sending Unit Volts Too High
Description of Diagnostic Trouble Code = Circuit shorted to voltage between PCM and fuel gauge sending unit.
Hex Code = 97
Generic Scan Tool Code = P0460
DRB Scan Tool Display = Fuel Level Unit No Change Over Miles
Description of Diagnostic Trouble Code = No movement of fuel level sender detected.
for additional information on troubleshooting and resolution:
http://rapidshare.com/files/138412864/ServiceManual.Jeep.Grand.Cherokee.1998_by_Parasico.rar
Mar 01, 2010 | 1998 Jeep Grand Cherokee
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
How do i use this?
Sharp SF2414, Сode
CH If lit steadily, paper feed section cover is open or manual feed unit not installed properly. If flashing, developer seal still installed, or toner density sensor/main board problem. EE Sub code EU: undertoned. May be toner density sensor problem or developer unit problem. Sub code EL: Over toned. May be toner density sensor problem or developer unit problem. H2 Sub code 0: Fuser thermistor. H3 Sub code 0: Fuser temperature too high. H4 Sub code 0: Fuser temperature too low. L1 Scan problem. Sub code is 0, but there is no more detail. Could be no scan drive; scan did not leave home; scan did not return home; scan overloaded; mirror motor problem; scan cable came off. L3 Scan return problem. Sub code 0. Approximately same causes as L1 L4 Sub code 1: Main drive problem. Sensor, gear, motor. L5 Sub code 2: Lens drive, motor, sensor. L8 Sub code 1 Power frequency varies by more than 5 % or for more than 5 sec. Sub code 3: AE sensor problem. PC Key counter not installed. SPFJAM Document feeder problem. U2 Sub code 1: Main board EEPROM problem. Sub code 4: Memory problem. U5 Sub code 5: high temperature at exposure glass when using document feeder
Apr 03, 2009 | Sharp Office Equipment & Supplies
Can not scan Code 128 bar code
you should have a code book with the scanner setup barcodes in it, you need to enable code 128 by scanning the appropriate codes in the code book.
Sep 26, 2008 | Symbol LS2208 Handheld
Remote control code
Dish Netork does not have the code for Olevia
but you can scan for the code using the infformation
here
Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control.
2. Press the Mode button on the remote until the appropriate mode light is flashes
3. Press the Address button. The mode light will start flashing slowly.
4. Press the Power button. The mode light will stop flashing and stay lit.
5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8. Turn the device back ON by pressing the Power button.
9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Nov 23, 2007 | Olevia LT32HVM 32 in. LCD Television
Westinghouse Electric LD4655VX TV Logo
22 people viewed this question
Top Westinghouse Electric Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Neil Frazier
Neil Frazier
Level 1 Expert
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
