Question about Hunter Televison & Video
Fan and light won't turn on. changed batteries on G0878-01 remote but didn't help.
3 Suggested Answers
  • 10865 Answers
SOURCE: wall remote that controls ceiling fan & lights not working
Either the bulb is blown or the connection under the wire nut is loose. First check the bulb then turn off the power at the panel and check each wire nut by unscrewing it and making sure that the wires are tightly twisted together before reinstalling the wire nut.
Posted on Apr 06, 2009
gopakumarg43
  • 74468 Answers
SOURCE: remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
Posted on Nov 14, 2011
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
Why won't my light or ceiling fan come on? I have changed the batteries in the remote. It is twelve years old.
We are desperate to find one of these fans..I will buy it for 75 so it can match the 7 other ones I have and I will use my parts to make it work..Scott 321-228-3081 THANKS>>I just have soo many and I need my house to all match
Apr 30, 2013 | Craftmade International Televison & Video
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Why won't wireless mic turn on the "Ready" light on receiver?
The handheld is in a different frequency band than the receiver. There are stickers on both that saw what frequency range they can tune to.
Apr 27, 2012 | Shure UT2 / 58 / PG58 Professional...
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
Remote to tv doesn't work
Hello
Nov 14, 2011 | Televison & Video
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
My ceiling fan/light goes on when I am not in the room. The remote is on the bureau. I sometimes put the remote in another room but the fan/light still goes on. Model 327185-060
The simple solution is to turn the wall switch OFF when, the fan is not in use. I really don't think the remote alone is the culprit. Because, you say it happens even when it's in the bureau or in another room. Remote controls for ceiling fans have a very short range and are generally infrared remotes, rather than radio frequency remotes. So, if the infrared signal does not reach the receiver's sensor in the fan, it won't function. If it's a radio frequency remote control, do you have any other remote controlled fans in the house? If so, does the suspect fan seem to turn ON after you have activated the other fan? If that happens, it means both remote controls are on the same frequency. Changing the frequency of one, should solve the problem. See your Owner's Manual for directions on how to reprogram the frequency codes.
If none of the above solves the problem, maybe you should contact the "Ghost Hunters" TV show.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 23, 2011 | Hunter Heating & Cooling
The remote for the fan quit working. New batteries didn't solve the problem. The are no strings to pull on/off, just a light switch which does turn on the light.
Just in case, I'll ask, Did you also change the remote receiver batteries, located behind the fan's cowling? If not, that should do the trick. Don't feel bad if you didn',most folks do remember they're there.
Jun 09, 2011 | Hunter Heating & Cooling
Televison & Video Logo
51 people viewed this question
Top Hunter Televison & Video Experts
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Henry  Thomas
Henry Thomas
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
