Question about Norelco Phillips Electric Razor Replacement Shaver Head Blades HQ4, Ge
How do I put back together the blade assembly of Phillips NorelcoRQ11 Sensa touch shaver
RQ11
5 Suggested Answers
  • 3 Answers
SOURCE: Replacing Heads for 8140XL Norelco shaver
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Posted on May 13, 2009
brector3
  • 1625 Answers
SOURCE: The blades came off the
You will find an instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/philips_norelco_heads_replacement
Posted on Nov 08, 2010
brector3
  • 1625 Answers
SOURCE: My father dropped his new
You will find a helpful video at shaveroutlet.com. See link below
Posted on Dec 17, 2010
brector3
  • 1625 Answers
SOURCE: Cannot put blade assembly back together
See video at shaveroutlet.com
http://shaveroutlet.com/philips_norelco_heads_replacement
Posted on Apr 12, 2016
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
Have Oster model 23-51f fast feed trimmer. Took the blade off havinv trouble putting parts back together namely small copper plate approx. 1-cm long, also having trouble getting the blades to fit together...
We also have these model clippers and have found out that the modelo number has been updated to 76023-510 type in Oster professional products for more info....hope this helps
Sep 22, 2010 | Oster 76915016002 Hair Trimmer
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
Sounds strange, since I don't think that the HQ5 heads in the shaver have the pointy parts that other shaver heads have. If your comb has 2 pointy edges, make sure they are located correctly in the head housing - they will need to be located inwards, with the the spindle that the retaining bracket attaches to in the center of the the two pointy parts.
But apart from placing the combs in first, locating the cutters in then putting the retaining bracket in (which may be broken if it won't fasten properly) I'm not sure what you can do, other than calling your local Philips Service Centre,
Apr 07, 2009 | Norelco Reflex Shaver 5885XL Electric...
How do I put my shaver back together after I replaced the blades?
For Remington clippers, the smaller blade has a groove which matches a beveled edge on the trimmer body. Line it up, align the larger blade to its screw holes, insert and fasten screws until tight, and you're good to go. Oh yeah, and try to center the small blade.
Mar 12, 2009 | Health & Beauty
Norelco Phillips Electric Razor Replacement Shaver Head Blades HQ4, Ge Logo
69 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
