Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Unclog dishwasher drain - GE 24 in. GSD6660GSS Built-in Dishwasher
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: If there is trash blockage
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Aug 29, 2010
Dishwasher not draining
drain hose should be attached to drain under the sink. pull it loose from that drain should be a small hoe with a black end on it. use a wire coat hanger to run through the hose to loosen clog.
Jan 23, 2013 | Bosch SHX45L05UC Dishwasher
Water will not drain out of dishwasher. How can I unclog it?
heatman101
Feb 06, 2011 | GE Profile 24 in. Built-In Dishwasher...
I have standing water in my dishwasher. How do I unclog the drain?
It will be smelly water and if you have access to a shop vac that will help you remove the standing water if not use a bowl or turkey blaster listed below.
Use a small bowl to remove standing water from washer to access screen to remove and check for blockage. Once you have removed all the water that you can with a bowl or cup. You can use a turkey blaster to sucton remaining water from dishwasher.
Then you remove screen and clean out drain and also check drain line for blockage from dishwasher to under sink.
Clean out drain to unclog in bottom of dishwasher and you may have to remove drain line to clean it.
Aug 10, 2010 | Frigidaire Dishwashers
My dishwasher is draining properly.
yes there is cleaners.Check filters at bottom of machine fiirst,then buy an cleaner.adrian,,,,
Jul 15, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
Won't drain at bottom.
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 23, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
The dishwater does not drain out water
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
Jan 07, 2010 | Kenmore Dishwashers
Won't Drain
pull the dishwasher out.. disassemble the drain tube and look for obstruction .. first let the water out!
Mar 10, 2009 | Dishwashers
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
21 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
