Question about Breville Kitchen Appliances - Others
Handle won't stay down
Ct75xl
2009 190cc Briggs starts but won't run
Ensure the oil is full. It has an oil low sensor. 30w oil.
Jun 13, 2013 | Toro Garden
Hatchback won't lock on saab 9-3
I had the very same problem with my 2002 Saab 9-3 after I manually moved the trunk latch to the locked position "out of curiosity..." Then I noticed there is a handle you can pull to release latch opening it up! Very simple remedy... It is a glow in the dark green plastic handle hanging down when the trunk/hatch is open dead center, just in slightly behind latch... Gently pull handle until you hear and see the latch click into the open position...Let me know how You make out. BTW: Toyota Camry has the same set up,same color as well...lol Good Luck!
Oct 16, 2012 | 2002 Saab 9-3 SE
De Longhi CT021.A x 2 slice toaser - Won't stay down
Is it plugged in. You may have to do a little handy work, unplug the unit and look to see where it catches when the handle is in down position, you may have to open the bottom door. There is a little catch when the handle is down it may need to be bent a little not much.
Oct 15, 2012 | DeLonghi RT200 Retro 2-Slice Toaster
Ice bin metal handle won't stay up?
It may have just popped out of place and needs to be re-adjusted, but if that''s not the case then the modular head has broken on the ice maker and it should be replaced
Jun 05, 2012 | Refrigerators
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
I have a crank style patio umbrella that won't stay up when we try to crank it up. How do I fix this? You crank it up and it just rolls back down when you let go of the crank.
We had the same problem. We simply used a bungee type cord to hold the crank handle in place once the umbrella had been opened.
Jun 26, 2011 | Garden
Toaster will not stay down when you put toast in
I found that the problem was caused by crumbs getting onto the electro-magnets that hold the toaster down, and onto the contacts that supply power to the magnets ant elements. Removing the cover was the trickiest part - my machine had screws with triangular holes in the heads that a normal screwdriver would not fit. I found, however, that these are the same screws as used in McDonalds Happy Meal toys, and you can get special drivers on ebay or from amazon for them. After that it was just a question of cleaning all the contact points inside the toaster (make sure the toaster is UNPLUGGED!!). 15 minute job.
Oct 04, 2010 | Breville CT75XL 4-Slice Toaster
Lever stopped working
mcdevito75 here, Sounds like the return spring on the laver is mis-aligned, see any appliance repair shop in your area.
Jun 28, 2010 | Breville CT75XL 4-Slice Toaster
Lever will not stay down unless you hold it down to cook the toast
The latching relay is either faulty, or the timer module has faulted. That usually happens when the Toaster has a "Fault" on it. I suspect that the Timer has faulted. Toasters really aren't usually fixed, but if you have a handy appliance repair shop why not get a quote, for a repair, or replacement.
Mar 25, 2010 | Breville CT75XL 4-Slice Toaster
Kitchen Appliances - Others Logo
71 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
