Question about Garden
Agents for bolens iseki diesel tractor G174
Blowing oil out of gear stick and dip stick
  • 375 Answers
SOURCE: GMC Vandura 1983 6.2 litre diesel automatic transmission oil GMC Vandura 1983 6.2 litre diesel automatic
Your dip stick tube is your fill tube for your transmission . Make sure your transmission oil is at opperating temp before servicing some instructions are written on the dip stick , Use a small funnel , Add a little at a time (cup). Use the proper fluid , check regularly
Posted on May 18, 2008
  • 133 Answers
SOURCE: Where is the gear box oil check dip stick
there is no dip stick on this car, there is a allen key screw on the gearbox  sump, the temperature for this check is stamped on the sump. its a job for a garage  as the car has to be level you remove the screw and oil should only trickel out the filler is on the side of the box  D
Posted on Jan 29, 2009
emissionwiz
  • 76846 Answers
SOURCE: I can't locate the transmission fluid dip stick for 2003 Grandam
Your transmission is sealed and has no dip stick, checking the fluid level properly involves using a factory scan tool.
Posted on Apr 26, 2009
SOURCE: I have oil blowing out of the dip stick on a JD
Nothing serious. A new o-ring for the cover. No more problem.
Posted on Jun 21, 2009
  • 95 Answers
SOURCE: Husqvarna YTH2448 engine leaking oil
That sounds like the sump gasket is leaking, sometimes the briggs machining at the sump and head areas are a little rough and a bad fit can allow the gasket to blow,if it is leaking it is actually sucking air in rather than pushing oil out while it is running. You would have to drain oil, remove the engine turn it upside down,remove the oil pump cover plate( 3 small screws) pull oil pump rotor and drive shaft out,remove sump bolts,replace gasket and reassemble.Be sure to use a light coat of gasket sealer like black silicone.
Posted on Jul 30, 2009
How would my husband check oil level in a 190XT tractor, differential ?
check with a service agent
many tractors run the transmission oil and diff oil as common oil and there was a small dip stick close to the right foot heel or under the seat
down load the user manual and it will have how to check the oil
Oct 02, 2016 | RTO Allis Chalmers Tractor 190xt, 200,...
Hydrostatic transmission fluid needed for bowlens tractor
The Bolens or iseki G152 will take a "TDH" fluid. The local Tractor supplier told me that as long as it says "Transmission / Hydraulic" on the container I would be OK. Most of the newer (and some older, like ours) have a single sump for the Hydraulics, differential, and Transmission and this is the product most of them use. I've been putting that in on my G152 (tx1502).
Any local tractor supply will have it. Even NAPA auto parts carries a TDH fluid. Again, whatever brand you get make sure it says "transmission / hydraulic" on the label.
Flyer
May 26, 2016 | Garden
How do i fix a 3 point hydraulic system on a bolens iseki g194 tractor?
if it's possible that cylinders are rusted or bent , with engine off you;ll need to loosen , both hydraulic lines from cylinder , use a pry bar to pry down , if it still wont move your gonna have to pull both pins from ends of cylinder and replace cylinder , a company in wisconsen makes any cylinder you'd ever need
Dec 11, 2014 | Garden
Bolens lawn tractor is blowing air out the intake. It's getting fire but won't start.
if this engine is blowing air out the carb when cranked over , i ask did the engine reciently get overheated, this sounds some what serious could be a head gasket or valve timing issue either one requires an experts hand to diagnose and fix it
does crankcase oil fill port blow oil out as well when cranked over ?
Jun 01, 2014 | Garden
17hp briggs and stratton blowing oil out of dipstick
looks the rings are stuck.when you have head off check piston. john.
Mar 10, 2014 | Briggs & Stratton Garden
Why is my diesel blowing oil from the dip stick?
Sounds like blow-by...due to worn piston rings. (Compression that gets pushed past the rings, into the engine crankcase, and out the dip stick tube.) Make sure that a vent may not be plugged.
Sep 08, 2011 | Isuzu Trooper Cars & Trucks
My ford 8210 will not move when gear is selected and the oil light is warning even although there is enough oil on dip stick. also link arms will not lift
there is a dip stick on the back end up top on the left side. It is probably low on oil.The filler cap is on the right. Use 10w 30 oil and that should sort you out. Otherwise it sounds like the hydrulic pump could be at fault.
Jan 10, 2011 | Fender Ford Tractor Suport Late Models...
May 18, 2008 | 1989 GMC Dura
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
