Question about Vehicle Parts & Accessories
Rear suspension Toyota corolla
    New Friend:
  • 24 Answers
What's the question? Its got one. Needs to have good shocks/struts to function properly. Can you get more specific, please?
Posted on Dec 10, 2014
Where is the vss on the 2009 corolla? i know its on the transaxle but Im having a hard time locating it..
http://www.toyotanation.com/forum/324-10th-gen-corolla-2nd-gen-matrix-suspension-brakes-wheel-forum/381204-2009-rear-speed-sensor-problem.html
Apr 07, 2015 | 2009 Toyota Corolla
2002 toyota corolla rear suspension arms. Driver side. Had to drop fuel tank a bit to remove long top bolt. Bottom bolt won't come loose. Is it secured in there or do I need to heat it and break it loose....
Soak with penetrating oil then use a socket on a big bar it will come loose. As for heat unless you have an welding torch you wont get very far but a good penetrating oil will help.
Sep 20, 2014 | 2002 Toyota Corolla
How to rectify 2006 corolla rear wheel drive wheel alignment issues with non adjustable rear end (toe in & camber). Is there any aftermarket kits or other ways to solve these issues.
Since the rear wheels do no steering, there is no toe in or camber adjustments. Why do you believe you need these to be adjusted? Has the car been in an accident and the rear suspension is out?
Nov 07, 2010 | 2006 Toyota Corolla
Coil above rear driver's side tire is practically
Blown suspension. You need to replace the spring and check the suspension spring supports. Also check all the others front and rear.
Nov 04, 2009 | 1994 Toyota Corolla
Rear Bearing Problem
These hubs are generally well packed by the manufacturer. If you are going through that hub/bearing at that rate, greasing is likely not your problem as you would see this problem surface with the other hub/bearing as well. Check rear suspension for damage & alignement.
May 02, 2009 | 2005 Toyota Corolla
Toyota carina e mcpherson strut problems
It should be the same, the only difference is the front suspension will have heavier coil springs to cope withe the diesel engine.
Rear will be identical as long as its off the same year car.
TL
Feb 12, 2009 | 2005 Toyota Corolla
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
