Question about Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Lens to camara contact at full zoom
When I zoom out to full zoom,anerror message shows up saying I need to clean the contacts. It onlt does this at full zoom, If I back it down a little, it works fine.
3 Suggested Answers
  • 134 Answers
SOURCE: Tamron 200-500mm lens on Canon 40D ... when I put
Try gently cleaning the electronic contacts on the lens's mount with an eraser. This will remove any mild oxidation on the contacts. If this doesn't resolve the problem, then contact Tamron and ask if there are any issues using this particular lens with a Canon 40D.
Posted on Apr 21, 2009
elix0411
  • 3530 Answers
SOURCE: Error 99 with a Canon
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
Posted on Jun 06, 2011
Err 1 message
Err 01
Description: The communication between the camera and lens is faulty.
Resolution: Very gently clean the electrical contacts (highlighted in red) on the camera and the lens using a clean and dry cloth.
Mar 24, 2013 | Canon EF 75-300mm Lens
I have a Sigma DL Zoom 75-300 mm lens that I would like to use on my new Canon Rebel T3i SLR camera. Part of the time when I try to use it, an error message comes up saying, "The lens is having...
Simply clean your camera lens contacts
Here is a tutorial , how to clean your camera lens contacts
http://www.youtube.com/watch?v=wUt-K6w7lc0
Good luck and regards
Sep 29, 2011 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Hi, I have a canon eos rebel xs. the mirror is kind a dirty, can it be cleaned by me or need to have it cleaned at canon service centers?s I also have a Tamron Telephoto lens, when I do a full zoom in...
This is a digital camera and I suspect it's not the mirror that's showing dirt it's the sensor. If you are seeing small bits of dirt on your pictures then it's dirt on the sensor. I would suggest having it cleaned at a camera store or repair facility if you are not comfortable with doing it yourself. Cleaned improperly can damage the sensor and renter the camera pretty well useless. The dirt inside the Tamron lens I would also suggest cleaning and if you are getting an error message you may as well send the camera in for a complete cleaning. There are kits on the marked to clean the sensors but again if you are not confident that you can do this then sent it to people that can and do it on a regular bases.
Sep 25, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Sp 550. zoom starts to come out on start up then clicking noise, screen shows zoom error then zoom retracts then powers off
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean both ends of the batteries, place them back in the camera and give them a full charge. This cleaning clears the problem about 80% of the time. If it doesn't work for you, it may be time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 05, 2010 | Cameras
Zoom error, lens dont come out at all
If you've recently dropped the camera you may have lens damage that's preventing the camera from working properly. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 20, 2009 | Fuji FinePix A900 Digital Camera
My digital camara no longer wants to work. The
The lens may have malfunctioned. It could be jammed, one of the plastic moving parts is broken, or the motor has malfunctioned.
You can try to open the r742 camera and swap out the lens with working set from another non-functioning r742 camera.
Oct 19, 2009 | HP Photosmart R742 7.0 Megapixel Digital...
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Lens error, restart camara issue in SD900
well **** that doesnt sound complicated or anything.
Feb 29, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Tamron 28-300mm f/3.5-6.3 DI XR for Canon Logo
21 people viewed this question
Top Tamron Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
