Question about Welding Tools
Spectrum 375 temp light
My temp light cycles on as soon as I turn the power switch on although the unit is dead cold. I used the machine for about 5 minutes when it initially came on so I waited for it to cool, it cycled on and off 3 times, and so I shut it down. Now it comes on as soon as I turn it on. Any help would be greatly appreciated
chillmaster
  • 104 Answers
SOURCE: Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Posted on Jul 02, 2008
  • 4 Answers
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Posted on Sep 02, 2008
  • 2318 Answers
SOURCE: Sony KDF-50WE655 won't turn on.
if your TV blinks 10 times. Possible solution should be to check and replace on the G1 board Q1600 and Q1601 if shorted and R1614 and diode D1605 open.
Posted on Oct 20, 2008
outdoorsman5
  • 631 Answers
SOURCE: I am looking to purchacs a slightly used miller
The main thing that can hurt these things is water. If he didn't have a water filter on the line before it enters the plasma it could destroy the unit. If you buy it try it out to see if everything works. When you install it be sure to buy a filter that they sell for these and put it on before the air enters the plasma. Around $400. to $600 to replace the parts when water meets with the components. The filter that Norco Welding supplies sells for these is a toilet paper filter and you need to check it often.
Posted on Jul 29, 2009
SOURCE: printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Posted on Sep 14, 2009
My rooftop a/c unit makes a compressor noise as soon I as plug in my travel trailer. It's a 2009 Outback Sydney edition 310 bhs with a dometic a/c unit I believe. basically with the thermometer switch to...
The system blows cold air when turned to on position but also makes that sound between cycles
NOTE THE ON / AUTO SWITCH BETWEEN GREEN,FAN AND YELLOW ,COOL TERMINALS ON THE THERMOSTAT,
THE FAN SWITCH NORMALLY CLOSED GOES TO LOW, HEAT SPEED, WHILE THE NORMALLY OPEN GOES TO THE HIGH SPEED, COLING SPEED.
BY TURNING FAN ON NOTHING BUT FAN SHOULD RUN..
SWITCHING THE BREAKER TO OFF PRECLUDES THE UNIT FROM DOING ANYTHING !
WHAT CAN IT DO WITH NO POWER!
I switch the breaker to the off position when not using the a/c in order to keep this cycle from occurring. A
Sep 16, 2013 | Dometic Rooftop RV Air Conditioner
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
Spectrum thunder plasma cutter will not cut steady, keeps stopping and have to pull trigger to cut
Check the contactor contacts for pitting. if severly pitted, replace contactor. If a death grip on the switch makes it work better then a light touch- replace the trigger switch.
Aug 17, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Will it run on house hold 240 volts
This machine will run on 115 or 230 volt standard house elctricity. There is a selector switch on the rear of the machine and you may have to change the plug on the power cord to suit your power outlet.
Feb 09, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Miller Spectrum 375 problem
It sounds like you have a problem in the power supply input area. Make sure your voltage select switch is in the correct location. Unplug the unit and switch back and forth between the two positions to clean the contacts. Try again. If still bad check you terminal lug connections on the input lead wires. If still bad please answer these questions.
Does the power indicator come on at all? Does the fan start?
Nov 12, 2009 | Miller Spectrum 375 Cutmate Plasma Cutter...
I am looking to purchacs a slightly used miller plazma spectrum 375 from a private owner is there any common problems related to this unit that I should look for?
Jul 29, 2009 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Temperature Control Problem
is washer less than a year old? if so call reapir ..there was an issue with the temp controls on a small number of those machines they use an electronic control in what looks like a mechanical switch..if over a yr old could still be a temp switch but be sure hoses are connected correctly and on a rinse cycle the water does come in hot ..don't worry too much about wash cycles temp is controlled to to prset temps and is based on final water temp in tub after fill not incoming water temp
Aug 06, 2008 | Whirlpool WTW5500S
Welding Tools Logo
70 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
