Question about Microsoft Xbox 360 Console
Graphics are a problem black boxes etc....
Graphics are the problem. black boxes appear.. Seems like a refresh rate or background has pixalated
  • someguy13o May 11, 2010
    what do you mean by black boxes. before my xbox got the rrod i would get strange gray boxes. is it similar to that?
  • 60 Answers
Replace graphic card
Posted on Jul 25, 2009
Fine tuning the contrast & darkness
Right click the display go to properties and on the advance tab try reducing or advancing the refresh rate to see if there is a difference. If negative restore the rate to the original setting. Good Luck. Ed Pinero
May 29, 2014 | Envision Peripherals 19" envision g917w1...
Hanns g computer monitor flashes black screen with "adjusting"
press and check menu buttons by pressing button (auto adjust).also adjust screen resolution lowest and refresh rate
Dec 25, 2017 | Hanns.G Corporation Computers & Internet
Hello, I have been using my asus vw222u monitor for a while now, connected to my dell dimension 4600 pc. I have been running the resolution at 1024x768, and been getting relatively clear pictures, but...
Your graphics card will not support that refresh rate @ 1680x1050. you may need to upgrade your graphics card.
Here is the best price/performance card for your machine. and will support upto 2048x1536 @ 85Hz
Hope this helps.
http://www.scan.co.uk/products/512mb-pny-nvidia-geforce-6200-graphics-card-agp-8x-4-cores-d-sub-dvi-i-s-video-passive-cooling
Apr 22, 2011 | ASUS VW222U 22 inch LCD Monitor
I have a acer AX-1200 that worked fine for 2 years, now it won't boot up, it will show the loading bar and then eventually go to a message "Mode Not Supported" screen. i can after a long wait go...
VGA modes are old VESA standard video modes that are supported as legacy modes on most graphics cards. In general, on modern graphics cards, they have variable refresh rates so as not to cause problems with monitors that can't handle the lower refresh rates frequently associated with VGA modes. Sometimes, graphics cards do not adjust the refresh rate for the monitor, and this can cause problems of minimum refresh rate being exceeded. The LCD monitor possibly has a very strict minimum refresh rate, and thus cannot handle the VGA mode on its standard refresh rate as sent by the graphics card.
Dec 09, 2010 | Acer Aspire X1200-B1601A PC Desktop
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
Can you help me my computer says input signal out of range
This has to do with the refresh rate (hertz) of the monitor and whether the graphics card is capable of operating at that rate. So your graphics card is operating at a rate that is too high or too low for you monitor to receive. I've run into this when trying to use a giant monitor with an older graphics card. Are you doing that? Try a generic plug and play 17inch monitor and see if that works. Go into Control Panel, open Appearance and Themes, open Display, go to Settings Tab and click Advanced. You will see tabs for Adapter and Monitor. There you will find what is and is not supported as far as resolution and refresh rate.
Jan 04, 2009 | Computers & Internet
Monitor 'drop out'
Ok, the problem with the monitor for programs is actually the Vista Aero. Found out that even though many programs are Vista compatible they do not run with Aero-used program compatibility wizard which reverted Aero to Windows Classic and all is well. Not sure if similar problem is affecting web pages though.
Feb 14, 2008 | Acer Computers & Internet
Too many drivers installed, which ones to keep, which ones to uninstall?
1. uninstall or disable windows scripting
http://www.sophos.com/support/knowledgebase/article/10359.html
2. uninstall cataylst and install the oldest version possible from their site or from your box
3. reinstall the oldest or original via s3 pro savage driver
use a utility like advanced uninstaller pro if its hard to unsintall ur drivers
http://www.innovative-sol.com/uninstaller/
Dec 21, 2007 | ATI RADEON 7500 (64 MB) PCI Graphic Card
Screen problems
Have your tried reinstalling the video drivers? If you have exhausted any driver issues, it is most probably caused by the video card, try changing some color settings and profiles too including refresh rates, it might be a conflicting graphics driver...
Dec 09, 2007 | Computers & Internet
Viewsonic VA712b 17 " flat screen monitor
Realheadache, Unusual problem, it could be the resolution and refresh rate setting your PCs video card is currently set at. I don?t know if this will fix your problem but its worth a try: - Now go to your PC with the old monitor connected, right click anywhere on the desktop. - Left click Properties from the box that appears. - When the Display Properties box appears click on the Settings tab. - Make note of the screen resolution. - Change the screen resolution to 1024 x 768. - Click on the Advanced button in the lower right hand corner. - In the next box that appears click on the Monitor tab. - In the Monitor settings section of this page record the value of the Screen refresh rate. Then change it to 60 Hertz. - Close this and the Display Properties box by click on the OK button. - Now try connecting your new monitor. Let us know if this helps and as always please don?t forget to rate this posting.
Feb 04, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Microsoft Xbox 360 Console Logo
127 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
