Question about Stihl Garden
Pulling rope stuck - Stihl Garden
    Problem Solver:
  • 20 Answers
Either the recoil needs repair or the motor is frozen and needs to be replaced.
Posted on Jul 21, 2014
I have a Briggs & Stratton 5500 watts generator that I hardly pull the rope for start, begins stuck then its loosen again and again gets too hard to pull, any suggestions please help
If the unit is older it could have heavy carbon in the cylinder heads, it could be a ring sticking and binding, do a compression test. Compression is high or mechanical binding.
Feb 24, 2015 | Briggs Stratton Portable Generator 305cc...
I have a Stihl 025 that has become very hard to start because in the past couple of years, it has become difficult to pull the starting rope against what feels like excessive engine compression. Does this...
no
problem could be failing ring/s or excessive fuel in the crankcase causing excessive combustion pressure or hydraulic lock
check by pulling the plug and if that eases the problem and the engine free spins from the rope , overhaul the carby with new needle and seat and diaphragms
Nov 13, 2017 | Garden
CRAFTSMAN 16
sounds like bad compression rings on your piston try taking out the spark plug and then try pulling the rope if that works take an air compressor and check how much psi their is in the chain saw i believe i should have up to 150psi
May 07, 2012 | Garden
My craftsman garage door opener gets stuck when closing and always goes back up
Release the door from the opener by pulling down on the rope. Then you can operate the door by hand and see what is binding.
Sep 29, 2011 | Sears Craftsman LiftMaster Chamberlain...
CRANK ROPE IS IN A BIND OR STUCK
Hi, if you remove the recoil housing you have a good chance of freeing the rope if it's bound. Try pulling the rope to see where it's tangled and use a screw driver to pry it loose. Good luck.
Dec 22, 2010 | Homelite Consumer Products Backpack...
Pulon pro 200e cord is stuck and wont pull. It's stuck Cord seems to be stuck in the recoil positionl I was pulling it and it was retracting, I was pulling pretty fast because it would not start and the...
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers or a good flat-blade screwdriver.
Nov 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Rope will not retract.
I am assuming you tried to pull start and the rope is stuck out. Just try pulling the rope while it is out, but stand on the hedge trimmer. Sometimes when this happens to me, I just pull the rope a little extra and then hang onto it when it goes back in. Alot of times, I think the rope gets caught on the outside of the retraction pulley causing a tangle.
Aug 05, 2010 | Poulan Ght225 25cc Gas Hedge Trimmer
The rope on my generator gets stuck as i pull to turn it on
Assuming the rope stays on the internal pulley, it is NORMAL for the rope to require great force at points in the cranking cycle (once per revolution of the crankshaft). These are the compression strokes and the force is MANY times the initial pulling force. If the rope returns easily, then the starter assembly is probably normal. It takes a strong arm and fast movement to start the enginess via pull rope. Some units have a compression release to ease this a bit.
Mar 22, 2010 | Electrical Supplies
Stihl backpack blower starter rope is pulling harder and harder. When it dose pull it starts right up.
See if your rope pulley is opening up and allowing rope to double over on itself.When this happens the rope will wedge in pulley causing it to pull hard.
Nov 15, 2009 | Garden
Replacing starter pull cord on Cub Cadet mower
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
May 05, 2009 | Garden
Garden Logo
46 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
