Question about Stihl Garden
Flywheel won't turn or move - Stihl Garden
  • Stihl Master
  • 1,807 Answers
Depending on the engine, you may have a seized engine. If it a 4mix engine, it may have dropped a valve.
Posted on Mar 07, 2015
Replaced flywheel of 2004 yukon xl, now it won't shift into overdrive
check all electrical connections or see if any are caught in between engine an trans in the bellhousing
Mar 23, 2013 | GMC 2004 Yukon XL 1500 Denali
Tiller won't start
Best advice is to spray some ether in the carb, if that doesn't start it up, then check the spark plug.
Mar 17, 2013 | Mtd Garden
My Pfaff 130 will not sew when the foot peddle is pressed and the flywheel turns, but the big silver screw in the middle of the flywheel does not move. If I tighten the big silver screw and turn the...
Does the motor turn at all. Does it hum when turning it on. It may be burned or the pulley on the motor is loose. Tighten it up and that should get it . Let me know if that works.
Jan 31, 2013 | Sewing Machines
Nordictrack ASR 630 display won't start
see the steps and fix it according. God bless you
Console 1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Nov 18, 2012 | Nordic Track Nordictrack Ack Asr 630...
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
Baby lock bl4-736d won't stitch--It has not been used in about 6 years. It worked fine the last time it was used. I don't know where to oil or even if that is the problem.
If your machine has not been used in six years then it could have siezed up. If there is a threading up diagram inside the front looper cover then it may show the red oiling dots too. These are usually on the upper and lower loopers where they move through another metal part. And sometimes a red spot at the back of the stitching platform to oil internally.
But firstly, can you turn the flywheel manually towards you? Does the loopers and needles move through a stitch sequence when you do? If there is no movement and the flywheel is turning then probably a gear has failed in the main drive shaft, many machines have nylon gears now to lessen need for lubrication but the gear itself may split as it ages. Can be replaced but usually means dismantling most of the machine to do so. Definitely something for the BL technician though.
If you can move the flywheel and things are moving then I'd suggest you oil all the metal moving parts, rub some oil onto both blades and give everything a good clean out. Then manually turn it through stitch sequence several times to spread the oil, then plug it in and see if the machine will now run. Just take it slow and gentle. Then change the needles and thread it up and see if you can get it to chain off.
Hope this helps.
Oct 23, 2011 | Baby Lock Evolve
I have a old Snapper riding mower with an 8hp Briggs and Stratton engine, The other day it wouldn't crank so I changed the switch and the solenoid, the battery was fully charged and it still won't...
make sure thers power going into the starter
if there is then see if the starter is siezed, try turning the fly gear, but not just up against the flywheel but try turning the starter backwards to see if it moves
Jul 29, 2011 | Garden
Model 917-372832 Eager-1 5.5 HP . Stopped running . Won't restart. I believe the timing may of moved. How to remove the fly wheel to check key position? The key may have stripped. Hit a rock which may...
Hi, you are correct, the key will be sheered. Remove the top shroud and flywheel nut, then while pulling upwards on the flywheel have someone strike downwards on the crankshaft with a hammer and brass drift. Do not use a steel drift as it will damage the crankshaft. Hope this helps, regards Phil.
Jul 18, 2011 | Craftsman Garden
2000 Chevy s10 manual changed starter still won't start the starter is spinning but the engine won't turn over.
Do you have the correct starter and is it grinding, this sounds like a bad flywheel or wrong starter or even a bad one. look at teeth of flywheel and see if they are damaged. good day
Jun 19, 2011 | 2000 Chevrolet S-10
Garden Logo
63 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
