Question about Whirlpool ED2GHEXN Side by Side Refrigerator
Whirlpool model ed5kvexvb00 When we get water from the water dispenser it makes a loud noise then 5secs later the water flows. does not happen all the time
SOURCE: whirlpool side by side water dispenser not working
I had the same problem and it appear the cable set between the freezer door and refrigerator body has some wires broken. The cable is in the bottom right hinge. You can try moving the cable with fingers at the same time you're pushing the water lever.
While this is not going to be a permanent fix, at least it confirm where the problem is.
Posted on Nov 28, 2007
Maytag317
  • 1136 Answers
SOURCE: makes loud knocking noise under refrigerater side
Hi, Does this noise accure when the compressor is shuting off?
Posted on May 12, 2009
tborn6
  • 700 Answers
SOURCE: My whirlpool fridge, ice makerMy Whirlpool is not making ice. It has an in door ice dispensing system. It stopped making ice yesterday - what could be wrong?
lift the bar up to shut the maker offf and then turn it bakck on and wait.
Posted on May 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
aasc
  • 1606 Answers
SOURCE: Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Posted on Oct 31, 2009
Whirlpool side by side has low pressure with filter, works great without.
more than likely the saddle valve...the valve you or the plumber installed to tie into the water line and shut it off for filter install. it's getting clogged up. Turn it all the way off and on again 3 or 4 times this should clean out the little hole feeding thru the valve from the pipe.
hope this helps.
take a look here...pics of a saddle valve.
https://www.doityourself.com/forum/electric-large-kitchen-home-appliances/395295-ge-refrigerator-freezer-no-water-flow-ice-maker.html
Jan 25, 2018 | Whirlpool Refrigerators
Where is lightbulb in freezer whirlpool model ed5kvexvboo
The model number is probably ed5kvexvb00. The parts diagrams, http://www.searspartsdirect.com/model-number/ed5kvexvb00/1198/0165000.html , show four places with light bulbs. There is one light under the Refrigerator ice dispenser. (It's mounted on the Refrigerator Dispenser Motor Mount. The motor power a shaft through the ice bucket so that might block your view of the light cover.) There is a small 7 W light behind the dispenser control bracket. There is a single light near the top right of the freezer above an air duct clip. Finally there are two bulbs in the refrigerator above the air duct louver in the lower portion of the refrigerator. Use the Refrigerator Liner, Freezer Liner, Motor & Ice Container Parts and the Dispenser Front Parts diagrams above for pictures of the covers for several of the bulbs.
I hope this helps.
May 29, 2017 | Whirlpool Refrigerators
My Whirlpool Duet washer is making a loud squealing noise when filling with cold water, and/or the water is reduced to barely a trickle. It does not make the noise/reduce cold water flow every time.
Hi.
Try to remove the sand filter(s) from the inlet hose. Both on the valve and on the water crane(tap) end. Common problem.
Usually this is the problem, but not always.
/ Geir
Technical Engineer
Sep 27, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Replaced water filter on a Maytag refrigerator it uses whirlpool filter. when filter is replaced and you try to use the water dispenser you get a loud grinding noise from the filter, how do you fix this?
I need to know which model you have, because i would explain the issue you have better. I thin it would be a MSD model and it could mean a board collision in the touch panel to the dispenser.
Please let me know your model so I can help you further.
Good Luck
Sep 01, 2013 | Whirlpool Refrigerator Water Filter
Load knocking noise
these high efficiency compressors make noise when they are in defrost..you will sometimes hear water running, or tapping noise or even a popping noise. if it happens when its off in defrost.. it will only happen three or four times per day as this is the defrost frequency and nothing can be done without securing the heat exchanger to the suction line ..sometimes these come loose...
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Kitchen Aid water dispenser makes a hammering sound when in use.
this is a pressure problem . some times caused by line size . but generaly changing the water valve will correct this problem . ****
Jan 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Frigidaire won't make ice & dispenses only about 4 oz. cold water
Water frozen in the freezer supply line - you need to thaw out the freezer. About six hours, door open, turn freezer OFF. You'll need a cooler with dry ice for your frozen food. 99% certain it'll work after that.
May 26, 2009 | Freezers
Loud rattling grinding noise when pump is running, no water enters the machine.
Make sure the water is turned on to the machine, if it is then it sounds like a faulty water fill valve, just replace the fill valve, they can sometimes be cleaned but I would never trust one, they can always stick in the on position later and flood your house. Check to see if the valve is geting 120v ac before replaceing the valve, if it's getting voltage and no water is flowing then the valve is bad. You will need to borrow or buy a multi-meter for this test.
Feb 01, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool ED2GHEXN Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
